Date/Time: Wed, 30 Sep 2026 03:05:18 +0000
I want to scroll through 3 of the 10 charts in a chartbook.
View Count: 886
| [2021-12-17 21:01:21] |
| User14953 - Posts: 268 |
I want to scroll through 3 of the 10 charts in a chartbook. Say Chart 3, 6 and 9 are of current interest, have action. The remaining 7 charts are "incubating" and let's say may become interesting in 30 minutes, but for now and I do not want the incubating-7 in the rotation of the 3 Action-Charts. So I want to be able to Earmark, to Select those charts #3, 6, and 9. Next I'd Maximize one of the Action-Charts, say chart 6, and view it, then I want to see the next one in rotation so I hit the F9 key to go forward to #9, then hit f9 again to go forward to #3, then hit f9 again to go forward to #6 ... So X minutes roll by and I want to update my Hot-Charts, my Action-Charts or whatever name suits you guys. It turns out that I want to drop one of the Current Action-Charts, say drop #6, and I want to add Chart#10 and Chart#5. Now there are 4 Action-Charts in rotation. Rinse Repeat. Does that make sense? Is it doable? Date Time Of Last Edit: 2021-12-17 21:07:24
| [2021-12-17 22:52:40] |
| GravisHTG - Posts: 321 |
maybe use subinstance and chartbook and make a chartbook with only hot charts when its needed and have more flexibilities when it comes to interchange charts. I dont think its possible like you describe. Date Time Of Last Edit: 2021-12-17 22:53:33
| [2021-12-21 00:12:21] |
| Sierra_Chart Engineering - Posts: 25005 |
You can hide the charts you do not want to iterate through: Window, CB and CW Menus: Hide Window (Window) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
