Date/Time: Tue, 04 Mar 2025 15:10:21 +0000
Stocks only showing intrady date now not weekly and daily
View Count: 602
[2021-12-17 19:26:37] |
User798502 - Posts: 2 |
I am only getting intraday for stocks not daily and weekly - used to work Also Apple and NVDA have not been adjusted for stock splits etc - I assume others also |
[2021-12-17 21:50:19] |
John - SC Support - Posts: 38343 |
Get us your Message Log by following these instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a daily chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
