Date/Time: Tue, 04 Mar 2025 14:50:26 +0000
Is is possible to share my SC market data with another platform ?
View Count: 599
[2021-12-17 18:01:12] |
GravisHTG - Posts: 306 |
I wonder , if its possible As I would love to be able to send data for backtesting purpose . And if possible , ill subscribe to more data plan , as you are very competive for pricing, if not the best I could find ( live CME data for 4$ ) ! Date Time Of Last Edit: 2021-12-17 22:46:26
[2021-12-18 02:06:05] |
Sierra_Chart Engineering - Posts: 18641 |
You can export the data: Exporting and Importing Intraday Data Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-18 04:29:22] |
ok , and is it possible to automated the process of exporting ?
Date Time Of Last Edit: 2021-12-18 04:29:32
[2021-12-20 15:17:53] |
John - SC Support - Posts: 38341 |
Refer to the following study: Write Bar and Study Data To File For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
