Date/Time: Tue, 04 Mar 2025 15:21:46 +0000
[User Discussion] - Transferring to a new PC
View Count: 1748
[2021-12-17 17:46:29] |
Giles Troulan - Posts: 3 |
I currently have Sierra up and running the way I like it but I'm upgrading to a new PC. What is the best way to copy all my settings, Chartbooks, levels, broker accounts etc over? Can I just copy the folder in the existing hard drive and paste into the new PC? Any help is appreciated. |
[2021-12-17 18:03:46] |
GravisHTG - Posts: 306 |
Easy , Sierra chart does not need any reainstallation , Just copy your folder to any USB key and your set. Personally , I have a Dedicated SSD only for Sierra chart. |
[2021-12-17 19:31:30] |
John - SC Support - Posts: 38346 |
Refer to the following: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Simple Transfer/Copy of Sierra Chart Installation to Another Folder or Computer System There are other options as well on that same page if you just want to copy some files. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
