Date/Time: Tue, 04 Mar 2025 14:52:41 +0000
Linking with Tradovate
View Count: 1921
[2021-12-17 17:44:34] |
User186755 - Posts: 2 |
Hi, Im interested in linking my tradovate account with sierra charts but was unable to find any solid information on how to do so. Would be much appreciated if you could help me out with this. Thank you -mohammad |
[2021-12-17 17:52:32] |
User933209 - Posts: 38 |
You need to ask Tradovate for a CQG connection. It is a monthly subscription ($15)
[2021-12-17 18:00:40] |
Thank you. Will they setup a new sierra account for me or will it be under my current account?
[2021-12-17 18:06:51] |
Your current account. You would just need to sign in with the CQG username / password that Tradovate will provide into the sierra charts platform - CQG WebAPI option.
[2021-12-17 18:10:02] |
(In sierra chart) Global Settings -> Data/Trade Service Settings -> current selected service (click on dropdown) -> click on CQG WebAPI and input the given username / password that tradovate gave you
[2021-12-17 19:33:07] |
John - SC Support - Posts: 38341 |
Once you have the CQG credentials, then follow these instructions: CQG Trading Platform Service: Setup Instructions After you finish that setup, then open your chartbooks and select Edit >> Translate Symbols to Current Service in order to change the symbols to the CQG symbols. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
