Date/Time: Tue, 26 Nov 2024 02:21:39 +0000
Duplicate candles in Cruel Oil - CLM4
View Count: 1118
[2014-04-04 17:12:25] |
vrunrun - Posts: 53 |
Hello Sierra, As titled, pls refer to the attached. I tried delete and download but still nothing is changed. Pls help. Thks & Rgds Kevin |
[2014-04-04 17:17:18] |
This must be caused by some other study on the chart. Check the studies through Analysis >> Studies.
