Date/Time: Sun, 09 Mar 2025 01:24:35 +0000
Sierra Chart Reacting Very Slow
View Count: 1173
[2021-12-17 15:26:57]
User643426 - Posts: 127
I'm having a problem with Sierra chart reacting very slow. There is a delay when I make adjustments to a chart and when I place and remove orders from the DOM. I have 1.5 TB of hard drive space available and 64 GB of RAM. Is there any way to fix this delay?
[2021-12-17 15:47:18]
John - SC Support - Posts: 38516
Refer to the following:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
In particular note the subsections 30.47 and 30.48 within that page.
[2022-01-26 15:58:57]
I'm experiencing a significant delay on the platform when trading and have only 5 Days to load for all charts in the one chartbook I have open. I read the section and subsections you recommended for this issue. Is there a way I can measure the speed of the functioning of my platform to determine whether it's functioning at optimal speed? Is there anything else I can do to increase the speed of functioning other than reducing the days to load?
[2022-01-26 16:40:43]
All of the information we have is in Help Section 30 at the following link:
As noted above, sections 47 and 48 should be looked into first.
[2022-01-26 19:25:06]
Actually, the problem is that the platform connection keeps having to reconnect. My internet is stable on all other devices. Do you know how to fix this?
[2022-01-26 21:43:42]
Copy and paste your Message Log into this thread for us to see what errors you are getting.
[2022-02-24 16:06:49]
I'm having a problem with Sierra Chart again having to reconnect every few seconds. I don't get a message that it is disconnecting and reconnecting but the data and the clock on my chart skips every few seconds and is not delivering continuous data. I believe there may be software on my computer such as Windows Defender antivirus software that is causing this to happen. How do I fix this and look at the message log to diagnose this when it doesn't automatically pop up? Thank you.
[2022-02-24 17:05:52]
If you believe that it is related to other software, then stop the other software and see if it helps the situation.
If you can post your Message Log here, we can take a look through it and see if there is anything showing in there. Follow these instructions to get us your Message Log:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
Also refer to the information in the following section for issues with lagging/freezing:
[2022-02-24 17:37:13]
Here is my message log. Thank you:
Reading Internal Order ID file. | 2022-02-24 11:49:10.822
Reading Trade Orders file. | 2022-02-24 11:49:10.890
Reading Trade Positions file. | 2022-02-24 11:49:10.895
Reading Trade Account Data files. | 2022-02-24 11:49:10.898
UDPListener (1492). Port 22904 | Listening on UDP port 22904. | 2022-02-24 11:49:10.914
Software version: 2333 64-bit | 2022-02-24 11:49:10.914
Primary Thread ID: 7656 | 2022-02-24 11:49:10.914
Usage end date: 2022-03-22 | 2022-02-24 11:49:10.914
Enabled for: Advanced Features 2. | 2022-02-24 11:49:10.914
Enabled for: Sierra Chart Historical Data Service. | 2022-02-24 11:49:10.914
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-02-24 11:49:10.914
Enabled for: Delayed Denali Exchange Data Feed. | 2022-02-24 11:49:10.914
Enabled for exchange2: CME (Trading Account Required) | 2022-02-24 11:49:10.914
Enabled for exchange2: CBOT (Trading Account Required) | 2022-02-24 11:49:10.914
Enabled for exchange2: COMEX (Trading Account Required) | 2022-02-24 11:49:10.914
Enabled for exchange2: NYMEX (Trading Account Required) | 2022-02-24 11:49:10.915
Enabled for exchange2: fairx_exchange.data | 2022-02-24 11:49:10.915
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-02-24 11:49:10.915
Current selected Data/Trading service: CQG WebAPI | 2022-02-24 11:49:10.915
Custom symbol settings values: enabled | 2022-02-24 11:49:10.915
Chart Update Interval: 500 | 2022-02-24 11:49:10.915
Intraday Data Storage Time Unit: 0 | 2022-02-24 11:49:10.915
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-02-24 11:49:10.915
2022-02-24 16:49:10 Local computer time in UTC | 2022-02-24 11:49:10.915
2022-02-24 11:49:10 Local computer time in SC Time Zone | 2022-02-24 11:49:10.915
2022-02-24 16:49:07 Server time in UTC | 2022-02-24 11:49:10.915
Local computer UTC time and Server UTC time difference: 1 seconds. | 2022-02-24 11:49:10.915
Program path: C:\Sierra Charts\ | 2022-02-24 11:49:10.915
Data Files path: C:\Sierra Charts\Data\ | 2022-02-24 11:49:10.915
OS Version Number: 10.0 | 2022-02-24 11:49:10.915
Locale Setting: C | 2022-02-24 11:49:10.915
DLLs: mcV-rejection(1)_64.dll, mcV.Rejection.bars_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2022-02-24 11:49:10.921
Allowed protected custom studies: | 2022-02-24 11:49:10.921
Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1. | 2022-02-24 11:49:10.940
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-02-24 11:49:11.012
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-02-24 11:49:11.121
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-02-24 11:49:11.121
Received 5 login tokens. | 2022-02-24 11:49:11.287
Symbol settings MD5 received. Request ID: 1. | 2022-02-24 11:49:12.770
Symbol settings are up-to-date for cqg. | 2022-02-24 11:49:12.770
Files to Open on Startup | Opening file: TRADEPRO ES_Mar2021.My.Version.1.28.2022.Live.Trading.Cht | 2022-02-24 11:49:15.464
F.US.EPH22 [CBV] 5 Min #20 | Reloading chart. | 2022-02-24 11:49:15.836
F.US.EPH22 [CBV] 5 Min #20 | Performing continuous chart historical Daily data download for symbol F.US.EPH22 starting at last date in file. | 2022-02-24 11:49:15.912
Starting DelayedDownloadMonitoringTimer | 2022-02-24 11:49:15.912
Starting HDTimeoutTimer | 2022-02-24 11:49:15.912
Added historical Daily data request for F.US.EPH22 to the queue. | 2022-02-24 11:49:15.912
Triggering next historical data download in queue. | 2022-02-24 11:49:15.912
F.US.EPH22 [CBV] 5 Min #20 | Waiting for historical downloads to complete with the IDs: 1, | 2022-02-24 11:49:15.932
F.US.EPH22 [CBV] 5 Min #3 | Reloading chart. | 2022-02-24 11:49:15.938
F.US.EPH22 [CBV] 5 Min #3 | Waiting for historical downloads to complete with the IDs: 1, | 2022-02-24 11:49:15.961
F.US.ENQH22 [CBV] 2.50 Range #5 | Reloading chart. | 2022-02-24 11:49:16.002
F.US.ENQH22 [CBV] 2.50 Range #5 | Performing continuous chart historical Daily data download for symbol F.US.ENQH22 starting at last date in file. | 2022-02-24 11:49:16.009
Added historical Daily data request for F.US.ENQH22 to the queue. | 2022-02-24 11:49:16.009
F.US.ENQH22 [CBV] 2.50 Range #5 | Waiting for historical downloads to complete with the IDs: 2, | 2022-02-24 11:49:16.017
F.US.EPM21 240 Min #18 | Reloading chart. | 2022-02-24 11:49:16.092
Loading DLL: C:\Sierra Charts\Data\mcV.Rejection.bars.dll (mcV.Rejection.bars_64.dll). Handle: 66000000 | 2022-02-24 11:49:16.113
Error loading: C:\Sierra Charts\Data\mcV-rejection.dll. File not found or may be missing SCDLLName line. | 2022-02-24 11:49:16.117
F.US.EPH22 [CBV] 2.50 Range #2 | Reloading chart. | 2022-02-24 11:49:16.131
F.US.EPH22 [CBV] 2.50 Range #2 | Waiting for historical downloads to complete with the IDs: 1, | 2022-02-24 11:49:16.155
F.US.EPH22 2.50 Range #33 | Reloading chart. | 2022-02-24 11:49:16.167
F.US.EPH22 1 Min #19 | Reloading chart. | 2022-02-24 11:49:16.182
F.US.EPH22 1 Min #14 | Reloading chart. | 2022-02-24 11:49:16.192
F.US.EPH22 60 Min #6 | Reloading chart. | 2022-02-24 11:49:16.292
F.US.EPH22 [CBV] 1.25 Range #4 | Reloading chart. | 2022-02-24 11:49:16.449
F.US.EPH22 [CBV] 1.25 Range #4 | Waiting for historical downloads to complete with the IDs: 1, | 2022-02-24 11:49:16.494
F.US.EPZ21 1 Min #13 | Reloading chart. | 2022-02-24 11:49:16.576
F.US.EPH22 5 Min #16 | Reloading chart. | 2022-02-24 11:49:17.623
F.US.EPH22 5 Min #9 | Reloading chart. | 2022-02-24 11:49:17.790
F.US.EPH22 [CBV] Rev. 5t #1 | Reloading chart. | 2022-02-24 11:49:17.959
F.US.EPH22 [CBV] Rev. 5t #1 | Waiting for historical downloads to complete with the IDs: 1, | 2022-02-24 11:49:17.982
F.US.EPH22 [CBV] 1 Min #12 | Reloading chart. | 2022-02-24 11:49:18.257
F.US.EPH22 [CBV] 1 Min #12 | Waiting for historical downloads to complete with the IDs: 1, | 2022-02-24 11:49:18.280
F.US.EPH22 [CBV] #10 | Reloading chart. | 2022-02-24 11:49:19.066
F.US.EPH22 [CBV] #10 | Waiting for historical downloads to complete with the IDs: 1, | 2022-02-24 11:49:19.090
Files to Open on Startup | Opening file: TRADEPRO ES_Mar2021.My.Version.1.27.2022.Live.Trading.Cht | 2022-02-24 11:49:19.108
F.US.EPH22 [CBV] 5 Min #20 | Reloading chart. | 2022-02-24 11:49:19.309
F.US.EPH22 [CBV] 5 Min #20 | Waiting for historical downloads to complete with the IDs: 1, | 2022-02-24 11:49:19.331
F.US.EPH22 [CBV] 5 Min #3 | Reloading chart. | 2022-02-24 11:49:19.359
F.US.EPH22 [CBV] 5 Min #3 | Waiting for historical downloads to complete with the IDs: 1, | 2022-02-24 11:49:19.381
F.US.ENQH22 [CBV] 2.50 Range #5 | Reloading chart. | 2022-02-24 11:49:19.718
F.US.ENQH22 [CBV] 2.50 Range #5 | Waiting for historical downloads to complete with the IDs: 2, | 2022-02-24 11:49:19.728
F.US.EPM21 240 Min #18 | Reloading chart. | 2022-02-24 11:49:20.001
F.US.MESH22 [CBV] 2.50 Range #2 | Reloading chart. | 2022-02-24 11:49:20.211
F.US.MESH22 [CBV] 2.50 Range #2 | Performing continuous chart historical Daily data download for symbol F.US.MESH22 starting at last date in file. | 2022-02-24 11:49:20.667
Added historical Daily data request for F.US.MESH22 to the queue. | 2022-02-24 11:49:20.667
F.US.MESH22 [CBV] 2.50 Range #2 | Waiting for historical downloads to complete with the IDs: 3, | 2022-02-24 11:49:21.337
F.US.EPH22 2.50 Range #33 | Reloading chart. | 2022-02-24 11:49:21.714
F.US.EPH22 1 Min #19 | Reloading chart. | 2022-02-24 11:49:21.770
F.US.EPH22 1 Min #14 | Reloading chart. | 2022-02-24 11:49:23.003
F.US.EPH22 60 Min #6 | Reloading chart. | 2022-02-24 11:49:23.052
F.US.MESH22 [CBV] 1.25 Range #4 | Reloading chart. | 2022-02-24 11:49:23.630
F.US.MESH22 [CBV] 1.25 Range #4 | Waiting for historical downloads to complete with the IDs: 3, | 2022-02-24 11:49:23.821
F.US.EPZ21 1 Min #13 | Reloading chart. | 2022-02-24 11:49:24.995
F.US.EPH22 5 Min #16 | Reloading chart. | 2022-02-24 11:49:26.167
F.US.EPZ21 5 Min #9 | Reloading chart. | 2022-02-24 11:49:26.173
F.US.MESH22 [CBV] Rev. 5t #1 | Reloading chart. | 2022-02-24 11:49:26.181
F.US.MESH22 [CBV] Rev. 5t #1 | Waiting for historical downloads to complete with the IDs: 3, | 2022-02-24 11:49:26.203
F.US.MESH22 [CBV] 1 Min #12 | Reloading chart. | 2022-02-24 11:49:26.211
F.US.MESH22 [CBV] 1 Min #12 | Waiting for historical downloads to complete with the IDs: 3, | 2022-02-24 11:49:26.258
F.US.MESH22 [CBV] #10 | Reloading chart. | 2022-02-24 11:49:28.999
F.US.MESH22 [CBV] #10 | Waiting for historical downloads to complete with the IDs: 3, | 2022-02-24 11:49:29.022
Mapping F.US.EPH22 to ESH22. Service code: cme | 2022-02-24 11:49:29.179
HD Request # 1 | Downloading Historical Daily chart data for F.US.EPH22. Starting date: 2022-02-18. Service: cqg | 2022-02-24 11:49:29.272
HD Request # 1 | Requesting historical Daily data for ESH22 starting at 2022-02-17. SC External HD service. | 2022-02-24 11:49:32.056
HD Request # 1 | Receiving historical Daily data for F.US.EPH22 starting at 2022-02-18 | 2022-02-24 11:49:38.963
HD Request # 1 | Writing historical Daily data to the file F.US.EPH22.dly | 2022-02-24 11:49:38.963
HD Request # 1 | Bytes received: 243 | 2022-02-24 11:49:38.994
HD Request # 1 | Received 4 Daily data records from 2022-02-18 00:00:00 to 2022-02-23 00:00:00 (6.0 days) and wrote 3 records for F.US.EPH22 | 2022-02-24 11:49:38.995
HD Request # 1 | Completion time: 9s | 2022-02-24 11:49:38.995
HD Request # 1 | Daily data download complete for F.US.EPH22. Unique request ID: 1 | 2022-02-24 11:49:38.995
Removing historical data download ID 1. | 2022-02-24 11:49:38.995
Triggering next historical data download in queue. | 2022-02-24 11:49:39.146
Mapping F.US.ENQH22 to NQH22. Service code: cme | 2022-02-24 11:49:39.146
HD Request # 2 | Downloading Historical Daily chart data for F.US.ENQH22. Starting date: 2022-02-18. Service: cqg | 2022-02-24 11:49:39.397
F.US.EPH22 [CBV] 5 Min #20 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-02-24 11:49:39.495
F.US.EPH22 [CBV] 5 Min #20 | Reloading chart. | 2022-02-24 11:49:39.496
F.US.EPH22 [CBV] 5 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-02-24 11:49:39.514
F.US.EPH22 [CBV] 5 Min #3 | Reloading chart. | 2022-02-24 11:49:39.514
Mapping F.US.EPM21 to ESM21. Service code: cme | 2022-02-24 11:49:39.528
Starting DelayedDownloadMonitoringTimer | 2022-02-24 11:49:39.530
Starting HDTimeoutTimer | 2022-02-24 11:49:39.530
Added historical Intraday data request for F.US.EPM21 to the queue. | 2022-02-24 11:49:39.530
Intraday data recording state for symbol F.US.EPM21 is set to download 'Pending'. | 2022-02-24 11:49:39.530
Triggering next historical data download in queue. | 2022-02-24 11:49:39.530
HD Request # 3 | Downloading Intraday chart data for F.US.EPM21 to the file F.US.EPM21.scid. Service: cme | 2022-02-24 11:49:39.531
HD Request # 3 | Download start date-time: 2021-06-18 09:29:59.000000. File last date-time: 2021-06-18 09:29:59.991000 | 2022-02-24 11:49:39.531
F.US.EPH22 [CBV] 2.50 Range #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-02-24 11:49:39.531
HD Request # 3 | Using server: ds23.sierracharts.com port 10150 | 2022-02-24 11:49:39.532
F.US.EPH22 [CBV] 2.50 Range #2 | Reloading chart. | 2022-02-24 11:49:39.532
Socket (3) | Creating socket. | 2022-02-24 11:49:39.534
Socket (3) | New receive buffer size: 5242880 | 2022-02-24 11:49:39.534
Socket (3) | Connecting to IP: 216.1.90.130. | 2022-02-24 11:49:39.534
Added historical Intraday data request for F.US.EPH22 to the queue. | 2022-02-24 11:49:39.572
Intraday data recording state for symbol F.US.EPH22 is set to download 'Pending'. | 2022-02-24 11:49:39.572
Triggering next historical data download in queue. | 2022-02-24 11:49:39.572
F.US.EPH22 [CBV] 1.25 Range #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-02-24 11:49:39.576
F.US.EPH22 [CBV] 1.25 Range #4 | Reloading chart. | 2022-02-24 11:49:39.576
HD Request # 3 | Setting DTC encoding to Binary VLS | 2022-02-24 11:49:39.626
HD Request # 3 | Sending historical data logon request message. | 2022-02-24 11:49:39.626
Mapping F.US.EPZ21 to ESZ21. Service code: cme | 2022-02-24 11:49:39.702
Added historical Intraday data request for F.US.EPZ21 to the queue. | 2022-02-24 11:49:39.702
Intraday data recording state for symbol F.US.EPZ21 is set to download 'Pending'. | 2022-02-24 11:49:39.702
Triggering next historical data download in queue. | 2022-02-24 11:49:39.702
HD Request # 3 | Requesting Intraday data. Start date-time: 2021-06-18 09:29:59. Record interval: 0. Symbol: ESM21 | 2022-02-24 11:49:40.125
HD Request # 3 | Decompressing data. | 2022-02-24 11:49:40.162
HD Request # 3 | Receiving Intraday data for F.US.EPM21 starting at 2021-06-18 09:29:59.034000 | 2022-02-24 11:49:40.165
Socket (3) | CloseSocket call. | 2022-02-24 11:49:40.165
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-02-24 11:49:40.165
Socket (3) | Socket gracefully closed by remote side. | 2022-02-24 11:49:40.201
Socket (3) | Closed. | 2022-02-24 11:49:40.202
HD Request # 2 | Requesting historical Daily data for NQH22 starting at 2022-02-17. SC External HD service. | 2022-02-24 11:49:40.637
Historical data download thread signaled to stop. | 2022-02-24 11:49:40.638
HD Request # 3 | Received 7 Intraday data records from 2021-06-18 09:29:59.034000 to 2021-06-18 09:29:59.991000 (1.0 seconds) and wrote 0 records for F.US.EPM21 | 2022-02-24 11:49:40.638
HD Request # 3 | Completion time: 1s | 2022-02-24 11:49:40.638
HD Request # 3 | Intraday data download complete for F.US.EPM21. Unique request ID: 4 | 2022-02-24 11:49:40.638
Removing historical data download ID 4. | 2022-02-24 11:49:40.638
HD Request # 3 | Enabling Intraday chart updating for symbol. | 2022-02-24 11:49:40.638
Triggering next historical data download in queue. | 2022-02-24 11:49:40.638
Historical data for F.US.EPM21 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-02-24 11:49:40.638
HD Request # 4 | Downloading Intraday chart data for F.US.EPH22 to the file F.US.EPH22.scid. Service: cme | 2022-02-24 11:49:40.638
HD Request # 4 | Download start date-time: 2022-02-24 11:40:53.000000. File last date-time: 2022-02-24 11:40:53.384000 | 2022-02-24 11:49:40.639
HD Request # 4 | Using server: ds21.sierracharts.com port 10149 | 2022-02-24 11:49:40.639
Socket (4) | Creating socket. | 2022-02-24 11:49:40.640
Socket (4) | New receive buffer size: 5242880 | 2022-02-24 11:49:40.640
Socket (4) | Connecting to IP: 216.1.90.129. | 2022-02-24 11:49:40.640
F.US.EPH22 [CBV] Rev. 5t #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-02-24 11:49:40.641
F.US.EPH22 [CBV] Rev. 5t #1 | Reloading chart. | 2022-02-24 11:49:40.641
F.US.EPH22 [CBV] 1 Min #12 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-02-24 11:49:40.653
F.US.EPH22 [CBV] 1 Min #12 | Reloading chart. | 2022-02-24 11:49:40.653
HD Request # 4 | Setting DTC encoding to Binary VLS | 2022-02-24 11:49:40.765
HD Request # 4 | Sending historical data logon request message. | 2022-02-24 11:49:40.765
F.US.EPH22 [CBV] #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-02-24 11:49:40.818
F.US.EPH22 [CBV] #10 | Reloading chart. | 2022-02-24 11:49:40.929
F.US.EPH22 [CBV] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:49:40.959
F.US.EPH22 [CBV] 5 Min #20 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-02-24 11:49:41.012
F.US.EPH22 [CBV] 5 Min #20 | Reloading chart. | 2022-02-24 11:49:41.261
HD Request # 4 | Requesting Intraday data. Start date-time: 2022-02-24 11:40:53. Record interval: 0. Symbol: ESH22 | 2022-02-24 11:49:41.347
HD Request # 2 | Receiving historical Daily data for F.US.ENQH22 starting at 2022-02-18 | 2022-02-24 11:49:41.371
HD Request # 2 | Writing historical Daily data to the file F.US.ENQH22.dly | 2022-02-24 11:49:41.371
HD Request # 2 | Bytes received: 259 | 2022-02-24 11:49:41.373
HD Request # 2 | Received 4 Daily data records from 2022-02-18 00:00:00 to 2022-02-23 00:00:00 (6.0 days) and wrote 3 records for F.US.ENQH22 | 2022-02-24 11:49:41.373
HD Request # 2 | Completion time: 2s | 2022-02-24 11:49:41.373
HD Request # 2 | Daily data download complete for F.US.ENQH22. Unique request ID: 2 | 2022-02-24 11:49:41.373
Removing historical data download ID 2. | 2022-02-24 11:49:41.373
Triggering next historical data download in queue. | 2022-02-24 11:49:41.373
Mapping F.US.MESH22 to MESH22. Service code: cme | 2022-02-24 11:49:41.373
HD Request # 5 | Downloading Historical Daily chart data for F.US.MESH22. Starting date: 2022-02-18. Service: cqg | 2022-02-24 11:49:41.374
F.US.EPH22 [CBV] 5 Min #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-02-24 11:49:41.377
F.US.EPH22 [CBV] 5 Min #3 | Reloading chart. | 2022-02-24 11:49:41.377
HD Request # 4 | Decompressing data. | 2022-02-24 11:49:41.377
HD Request # 4 | Receiving Intraday data for F.US.EPH22 starting at 2022-02-24 11:40:53.088000 | 2022-02-24 11:49:41.387
F.US.ENQH22 [CBV] 2.50 Range #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-02-24 11:49:41.392
F.US.ENQH22 [CBV] 2.50 Range #5 | Reloading chart. | 2022-02-24 11:49:41.394
Socket (4) | CloseSocket call. | 2022-02-24 11:49:41.577
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-02-24 11:49:41.577
Socket (4) | Socket gracefully closed by remote side. | 2022-02-24 11:49:41.613
Socket (4) | Closed. | 2022-02-24 11:49:41.613
Historical data download thread signaled to stop. | 2022-02-24 11:49:42.980
HD Request # 4 | Timestamp of first Intraday data file record written: 2022-02-24 11:40:54.064000 | 2022-02-24 11:49:43.033
HD Request # 4 | Received 25535 Intraday data records from 2022-02-24 11:40:53.088000 to 2022-02-24 11:49:37.462002 (8.7 minutes) and wrote 25533 records for F.US.EPH22 | 2022-02-24 11:49:43.033
HD Request # 4 | Completion time: 3s | 2022-02-24 11:49:43.033
HD Request # 4 | Intraday data download complete for F.US.EPH22. Unique request ID: 5 | 2022-02-24 11:49:43.033
Removing historical data download ID 5. | 2022-02-24 11:49:43.033
HD Request # 4 | Enabling Intraday chart updating for symbol. | 2022-02-24 11:49:43.033
Triggering next historical data download in queue. | 2022-02-24 11:49:43.033
Historical data for F.US.EPH22 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-02-24 11:49:43.033
HD Request # 5 | Requesting historical Daily data for ETH22 starting at 2022-02-17. SC External HD service. | 2022-02-24 11:49:43.033
HD Request # 6 | Downloading Intraday chart data for F.US.EPZ21 to the file F.US.EPZ21.scid. Service: cme | 2022-02-24 11:49:43.033
HD Request # 6 | Download start date-time: 2021-12-17 09:29:58.000000. File last date-time: 2021-12-17 09:29:58.216000 | 2022-02-24 11:49:43.033
HD Request # 6 | Using server: ds23.sierracharts.com port 10150 | 2022-02-24 11:49:43.033
Socket (7) | Creating socket. | 2022-02-24 11:49:43.034
Socket (7) | New receive buffer size: 5242880 | 2022-02-24 11:49:43.034
Socket (7) | Connecting to IP: 216.1.90.130. | 2022-02-24 11:49:43.034
CQG WebAPI | Connecting to server api.cqg.com | 2022-02-24 11:49:43.089
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2022-02-24 11:49:43.090
HD Request # 6 | Setting DTC encoding to Binary VLS | 2022-02-24 11:49:43.142
HD Request # 6 | Sending historical data logon request message. | 2022-02-24 11:49:43.142
CQG WebSocket socket (8) | Creating socket. Using TLS 1.2. | 2022-02-24 11:49:43.146
CQG WebSocket socket (8) | New receive buffer size: 5242880 | 2022-02-24 11:49:43.146
CQG WebSocket socket (8) | Connecting to IP: 208.48.16.35. | 2022-02-24 11:49:43.146
HD Request # 6 | Requesting Intraday data. Start date-time: 2021-12-17 09:29:58. Record interval: 0. Symbol: ESZ21 | 2022-02-24 11:49:43.177
HD Request # 6 | Decompressing data. | 2022-02-24 11:49:43.207
HD Request # 6 | Receiving Intraday data for F.US.EPZ21 starting at 2021-12-17 09:29:58.216000 | 2022-02-24 11:49:43.307
Socket (7) | CloseSocket call. | 2022-02-24 11:49:43.307
Socket (7) | Shutdown started. Waiting for graceful close. | 2022-02-24 11:49:43.307
Socket (7) | Socket gracefully closed by remote side. | 2022-02-24 11:49:43.342
Socket (7) | Closed. | 2022-02-24 11:49:43.342
CQG WebSocket | Opening WebSocket. | 2022-02-24 11:49:44.044
CQG WebSocket | Sending WebSocket handshake. | 2022-02-24 11:49:44.044
Historical data download thread signaled to stop. | 2022-02-24 11:49:44.044
HD Request # 6 | Received 1 Intraday data record from 2021-12-17 09:29:58.216000 to 2021-12-17 09:29:58.216000 (0.0 seconds) and wrote 0 records for F.US.EPZ21 | 2022-02-24 11:49:44.083
HD Request # 6 | Completion time: 1s | 2022-02-24 11:49:44.083
HD Request # 6 | Intraday data download complete for F.US.EPZ21. Unique request ID: 6 | 2022-02-24 11:49:44.083
Removing historical data download ID 6. | 2022-02-24 11:49:44.083
HD Request # 6 | Enabling Intraday chart updating for symbol. | 2022-02-24 11:49:44.083
Triggering next historical data download in queue. | 2022-02-24 11:49:44.083
Historical data for F.US.EPZ21 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-02-24 11:49:44.083
No download requests in the queue to start downloads for. | 2022-02-24 11:49:44.083
F.US.EPH22 [CBV] 5 Min #20 | Reloading chart. | 2022-02-24 11:49:44.107
F.US.EPH22 [CBV] 5 Min #3 | Reloading chart. | 2022-02-24 11:49:44.141
CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2022-02-24 11:49:44.601
CQG WebSocket | Server header | Connection: upgrade | 2022-02-24 11:49:44.601
CQG WebSocket | Server header | Sec-WebSocket-Accept: O9x+NRKKh8eGS9LJUvACFoHRTf8= | 2022-02-24 11:49:44.601
CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2022-02-24 11:49:44.601
CQG WebSocket | Server header | Upgrade: websocket | 2022-02-24 11:49:44.601
CQG WebSocket | Server header | | 2022-02-24 11:49:44.601
CQG WebSocket | Web socket state is now open. | 2022-02-24 11:49:44.601
CQG WebAPI | WebSocket connected. | 2022-02-24 11:49:44.628
CQG WebAPI | Sending market data logon message. | 2022-02-24 11:49:44.629
HD Request # 5 | Receiving historical Daily data for F.US.MESH22 starting at 2022-02-18 | 2022-02-24 11:49:44.832
HD Request # 5 | Writing historical Daily data to the file F.US.MESH22.dly | 2022-02-24 11:49:44.833
HD Request # 5 | Bytes received: 239 | 2022-02-24 11:49:45.026
HD Request # 5 | Received 4 Daily data records from 2022-02-18 00:00:00 to 2022-02-23 00:00:00 (6.0 days) and wrote 3 records for F.US.MESH22 | 2022-02-24 11:49:45.026
HD Request # 5 | Completion time: 4s | 2022-02-24 11:49:45.026
HD Request # 5 | Daily data download complete for F.US.MESH22. Unique request ID: 3 | 2022-02-24 11:49:45.026
Removing historical data download ID 3. | 2022-02-24 11:49:45.026
Triggering next historical data download in queue. | 2022-02-24 11:49:45.026
CQG WebAPI | Base Time: 2022-02-20T09:00:20. 2022-02-20 09:00:20 | 2022-02-24 11:49:45.109
CQG WebAPI | Logon successful. Session Token = MtLNTYtS/HaKIqBbrkYR+WW5lc51UrbS1fQqzr6YJ18AIaclQl27C30R2sG34aMtCvKH7bzIi6l | 2022-02-24 11:49:45.109
CQG WebAPI | Connected to server complete. | 2022-02-24 11:49:45.109
Triggering next historical data download in queue. | 2022-02-24 11:49:47.958
Updated verified funded futures trading account ending date to: 2022-03-26 16:49:48 | 2022-02-24 11:49:48.021
CQG WebAPI | Sending Trade Accounts request message. | 2022-02-24 11:49:48.022
No download requests in the queue to start downloads for. | 2022-02-24 11:49:48.023
No download requests in the queue to start downloads for. | 2022-02-24 11:49:48.025
F.US.ENQH22 [CBV] 2.50 Range #5 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-02-24 11:49:48.025
F.US.ENQH22 [CBV] 2.50 Range #5 | Reloading chart. | 2022-02-24 11:49:48.025
F.US.EPH22 [CBV] 2.50 Range #2 | Reloading chart. | 2022-02-24 11:49:48.035
F.US.EPH22 [CBV] 1.25 Range #4 | Reloading chart. | 2022-02-24 11:49:48.069
CQG WebAPI | Brokerage name: AMP. Account Name: 130360 | 2022-02-24 11:49:48.108
Updated verified funded futures trading account ending date to: 2022-03-26 16:49:48 | 2022-02-24 11:49:48.108
CQG WebAPI | Sending collateral subscribe request. | 2022-02-24 11:49:48.108
Mapping F.US.EPZ21 to ESZ21. Service code: cme | 2022-02-24 11:49:48.109
SC Data - All Services | Starting real-time market data updates for: F.US.EPZ21 (ESZ21). ID: 1 Service code: cme | 2022-02-24 11:49:48.109
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2022-02-24 11:49:48.110
CQG WebAPI | Sending symbol resolution request for F.US.EPZ21. ID: 184534 | 2022-02-24 11:49:48.110
SC Data - All Services | Requesting security definition data for: F.US.EPZ21 (ESZ21). ID: 1 | 2022-02-24 11:49:48.110
Added historical Intraday data request for F.US.EPZ21 to the queue. | 2022-02-24 11:49:48.110
Intraday data recording state for symbol F.US.EPZ21 is set to download 'Pending'. | 2022-02-24 11:49:48.110
Triggering next historical data download in queue. | 2022-02-24 11:49:48.111
DTC Client socket (1) | Creating socket. | 2022-02-24 11:49:48.111
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-02-24 11:49:48.111
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2022-02-24 11:49:48.111
Delaying start of download for F.US.EPZ21 | 2022-02-24 11:49:48.111
Mapping F.US.EPH22 to ESH22. Service code: cme | 2022-02-24 11:49:48.132
SC Data - All Services | Starting real-time market data updates for: F.US.EPH22 (ESH22). ID: 2 Service code: cme | 2022-02-24 11:49:48.133
CQG WebAPI | Sending symbol resolution request for F.US.EPH22. ID: 184535 | 2022-02-24 11:49:48.133
SC Data - All Services | Requesting security definition data for: F.US.EPH22 (ESH22). ID: 2 | 2022-02-24 11:49:48.133
Added historical Intraday data request for F.US.EPH22 to the queue. | 2022-02-24 11:49:48.133
Intraday data recording state for symbol F.US.EPH22 is set to download 'Pending'. | 2022-02-24 11:49:48.133
Triggering next historical data download in queue. | 2022-02-24 11:49:48.133
F.US.EPH22 [CBV] Rev. 5t #1 | Reloading chart. | 2022-02-24 11:49:48.137
SC Data - All Services | Network connection to server complete. | 2022-02-24 11:49:48.559
SC Data - All Services | Starting socket receive thread. | 2022-02-24 11:49:48.559
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-02-24 11:49:48.559
F.US.EPH22 [CBV] 1 Min #12 | Reloading chart. | 2022-02-24 11:49:48.560
CQG WebAPI | Received symbol resolution report for symbol F.US.EPZ21. Search Symbol: F.US.EPZ21. Request ID: 184534. Contract ID: 1. | 2022-02-24 11:49:48.593
CQG WebAPI | Received symbol resolution report for symbol F.US.EPH22. Search Symbol: F.US.EPH22. Request ID: 184535. Contract ID: 2. | 2022-02-24 11:49:48.594
F.US.EPH22 [CBV] #10 | Reloading chart. | 2022-02-24 11:49:48.594
F.US.EPH22 [CBV] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:49:48.627
Mapping F.US.EPM21 to ESM21. Service code: cme | 2022-02-24 11:49:49.558
SC Data - All Services | Starting real-time market data updates for: F.US.EPM21 (ESM21). ID: 3 Service code: cme | 2022-02-24 11:49:49.558
CQG WebAPI | Sending symbol resolution request for F.US.EPM21. ID: 184536 | 2022-02-24 11:49:49.558
SC Data - All Services | Requesting security definition data for: F.US.EPM21 (ESM21). ID: 3 | 2022-02-24 11:49:49.558
Added historical Intraday data request for F.US.EPM21 to the queue. | 2022-02-24 11:49:49.559
Intraday data recording state for symbol F.US.EPM21 is set to download 'Pending'. | 2022-02-24 11:49:49.559
Triggering next historical data download in queue. | 2022-02-24 11:49:49.559
F.US.MESH22 [CBV] 1.25 Range #4 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-02-24 11:49:49.560
F.US.MESH22 [CBV] 1.25 Range #4 | Reloading chart. | 2022-02-24 11:49:49.560
F.US.MESH22 [CBV] Rev. 5t #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-02-24 11:49:49.576
F.US.MESH22 [CBV] Rev. 5t #1 | Reloading chart. | 2022-02-24 11:49:49.577
CQG WebAPI | Received message: Requested symbol was not found. | 2022-02-24 11:49:49.598
Symbol Error - F.US.EPM21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2022-02-24 11:49:49.598
F.US.MESH22 [CBV] 2.50 Range #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-02-24 11:49:49.598
F.US.MESH22 [CBV] 2.50 Range #2 | Reloading chart. | 2022-02-24 11:49:49.598
F.US.EPH22 [CBV] 5 Min #20 | Reloading chart. | 2022-02-24 11:49:49.618
F.US.EPH22 [CBV] 5 Min #3 | Reloading chart. | 2022-02-24 11:49:49.661
F.US.ENQH22 [CBV] 2.50 Range #5 | Reloading chart. | 2022-02-24 11:49:50.893
F.US.MESH22 [CBV] 1 Min #12 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-02-24 11:49:50.905
F.US.MESH22 [CBV] 1 Min #12 | Reloading chart. | 2022-02-24 11:49:50.905
F.US.MESH22 [CBV] #10 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-02-24 11:49:50.919
F.US.MESH22 [CBV] #10 | Reloading chart. | 2022-02-24 11:49:50.919
F.US.MESH22 [CBV] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:49:50.930
F.US.ENQH22 [CBV] 2.50 Range #5 | Reloading chart. | 2022-02-24 11:49:50.962
Requesting market depth updates for: F.US.EPH22 if supported. | 2022-02-24 11:49:50.974
Separate subscription for market depth updates not supported. F.US.EPH22 | 2022-02-24 11:49:50.974
F.US.MESH22 [CBV] 1.25 Range #4 | Reloading chart. | 2022-02-24 11:49:51.013
SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-02-24 11:49:53.900
SC Data - All Services | Sending logon request message. | 2022-02-24 11:49:53.989
F.US.MESH22 [CBV] Rev. 5t #1 | Reloading chart. | 2022-02-24 11:49:54.194
F.US.MESH22 [CBV] 2.50 Range #2 | Reloading chart. | 2022-02-24 11:49:54.566
SC Data - All Services | Received logon response. | 2022-02-24 11:49:55.825
SC Data - All Services | Server Name: SC Realtime Server. | 2022-02-24 11:49:55.825
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-02-24 11:49:55.825
SC Data - All Services | Successfully connected. | 2022-02-24 11:49:55.825
SC Data - All Services | Trading is not supported. | 2022-02-24 11:49:55.825
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPH22 -> ESH22. Market Depth data restarted. | 2022-02-24 11:49:55.832
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPM21 -> ESM21 | 2022-02-24 11:49:55.832
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EPZ21 -> ESZ21 | 2022-02-24 11:49:55.832
CQG WebAPI | Sending positions subscribe request. RequestID: 184537 | 2022-02-24 11:49:55.837
CQG WebAPI | Sending orders subscribe request. RequestID: 184538 | 2022-02-24 11:49:55.837
Mapping F.US.ENQH22 to NQH22. Service code: cme | 2022-02-24 11:49:55.841
SC Data - All Services | Starting real-time market data updates for: F.US.ENQH22 (NQH22). ID: 4 Service code: cme | 2022-02-24 11:49:55.842
CQG WebAPI | Sending symbol resolution request for F.US.ENQH22. ID: 184539 | 2022-02-24 11:49:55.842
SC Data - All Services | Requesting security definition data for: F.US.ENQH22 (NQH22). ID: 4 | 2022-02-24 11:49:55.842
Added historical Intraday data request for F.US.ENQH22 to the queue. | 2022-02-24 11:49:55.842
Intraday data recording state for symbol F.US.ENQH22 is set to download 'Pending'. | 2022-02-24 11:49:55.842
Triggering next historical data download in queue. | 2022-02-24 11:49:55.842
F.US.MESH22 [CBV] 1 Min #12 | Reloading chart. | 2022-02-24 11:49:55.843
F.US.MESH22 [CBV] #10 | Reloading chart. | 2022-02-24 11:49:55.893
F.US.MESH22 [CBV] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:49:55.928
Mapping F.US.MESH22 to MESH22. Service code: cme | 2022-02-24 11:49:55.937
SC Data - All Services | Starting real-time market data updates for: F.US.MESH22 (MESH22). ID: 5 Service code: cme | 2022-02-24 11:49:55.937
CQG WebAPI | Sending symbol resolution request for F.US.MESH22. ID: 184540 | 2022-02-24 11:49:55.937
SC Data - All Services | Requesting security definition data for: F.US.MESH22 (MESH22). ID: 5 | 2022-02-24 11:49:55.937
Requesting market depth updates for: F.US.MESH22 if supported. | 2022-02-24 11:49:55.937
Added historical Intraday data request for F.US.MESH22 to the queue. | 2022-02-24 11:49:55.937
Intraday data recording state for symbol F.US.MESH22 is set to download 'Pending'. | 2022-02-24 11:49:55.937
Triggering next historical data download in queue. | 2022-02-24 11:49:55.937
CQG WebAPI | Received symbol resolution report for symbol F.US.ENQH22. Search Symbol: F.US.ENQH22. Request ID: 184539. Contract ID: 4. | 2022-02-24 11:49:56.189
CQG WebAPI | Received symbol resolution report for symbol F.US.MESH22. Search Symbol: F.US.MESH22. Request ID: 184540. Contract ID: 3. | 2022-02-24 11:49:56.189
SC Data - All Services | Clearing market depth for F.US.EPH22 | 2022-02-24 11:49:56.189
Opened cached Depth file: C:\Sierra Charts\Data\MarketDepthData\F.US.EPH22.2022-02-24.depth | 2022-02-24 11:49:56.198
SC Data - All Services | Received security definition for symbol F.US.EPH22 | 2022-02-24 11:49:56.199
SC Data - All Services | Clearing market depth for F.US.MESH22 | 2022-02-24 11:49:56.200
Opened cached Depth file: C:\Sierra Charts\Data\MarketDepthData\F.US.MESH22.2022-02-24.depth | 2022-02-24 11:49:56.207
SC Data - All Services | Real-time data for symbol F.US.EPM21 is currently unavailable. | 2022-02-24 11:49:56.207
SC Data - All Services | Received security definition for symbol F.US.EPM21 | 2022-02-24 11:49:56.207
SC Data - All Services | Real-time data for symbol F.US.EPZ21 is currently unavailable. | 2022-02-24 11:49:56.207
SC Data - All Services | Received security definition for symbol F.US.EPZ21 | 2022-02-24 11:49:56.207
SC Data - All Services | Received security definition for symbol F.US.ENQH22 | 2022-02-24 11:49:56.207
SC Data - All Services | Received security definition for symbol F.US.MESH22 | 2022-02-24 11:49:56.207
HD Request # 7 | Downloading Intraday chart data for F.US.EPZ21 to the file F.US.EPZ21.scid. Service: cme | 2022-02-24 11:50:01.033
HD Request # 7 | Download start date-time: 2021-12-17 09:29:58.000000. File last date-time: 2021-12-17 09:29:58.216000 | 2022-02-24 11:50:01.033
HD Request # 7 | Using server: ds21.sierracharts.com port 10149 | 2022-02-24 11:50:01.034
Socket (2) | Creating socket. | 2022-02-24 11:50:01.034
Socket (2) | New receive buffer size: 5242880 | 2022-02-24 11:50:01.034
Socket (2) | Connecting to IP: 216.1.90.129. | 2022-02-24 11:50:01.034
HD Request # 7 | Setting DTC encoding to Binary VLS | 2022-02-24 11:50:01.172
HD Request # 7 | Sending historical data logon request message. | 2022-02-24 11:50:01.172
HD Request # 7 | Requesting Intraday data. Start date-time: 2021-12-17 09:29:58. Record interval: 0. Symbol: ESZ21 | 2022-02-24 11:50:01.225
HD Request # 7 | Decompressing data. | 2022-02-24 11:50:01.287
HD Request # 7 | Receiving Intraday data for F.US.EPZ21 starting at 2021-12-17 09:29:58.216000 | 2022-02-24 11:50:01.289
Socket (2) | CloseSocket call. | 2022-02-24 11:50:01.289
Historical data download thread signaled to stop. | 2022-02-24 11:50:01.289
HD Request # 7 | Received 1 Intraday data record from 2021-12-17 09:29:58.216000 to 2021-12-17 09:29:58.216000 (0.0 seconds) and wrote 0 records for F.US.EPZ21 | 2022-02-24 11:50:01.289
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-02-24 11:50:01.289
HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2021-12-17 14:29:58.216000 | 2022-02-24 11:50:01.289
HD Request # 7 | Completion time: 0s | 2022-02-24 11:50:01.289
HD Request # 7 | Intraday data download complete for F.US.EPZ21. Unique request ID: 7 | 2022-02-24 11:50:01.289
Removing historical data download ID 7. | 2022-02-24 11:50:01.289
Real-time Intraday chart data file updates started for F.US.EPZ21 | 2022-02-24 11:50:01.290
Intraday chart data file opened for F.US.EPZ21 | 2022-02-24 11:50:01.290
HD Request # 7 | Enabling Intraday chart updating for symbol. | 2022-02-24 11:50:01.290
Triggering next historical data download in queue. | 2022-02-24 11:50:01.290
HD Request # 8 | Downloading Intraday chart data for F.US.EPH22 to the file F.US.EPH22.scid. Service: cme | 2022-02-24 11:50:01.290
HD Request # 8 | Download start date-time: 2022-02-24 11:49:37.000000. File last date-time: 2022-02-24 11:49:37.462002 | 2022-02-24 11:50:01.290
HD Request # 8 | Using server: ds23.sierracharts.com port 10150 | 2022-02-24 11:50:01.290
Socket (3) | Creating socket. | 2022-02-24 11:50:01.290
Socket (3) | New receive buffer size: 5242880 | 2022-02-24 11:50:01.290
Socket (3) | Connecting to IP: 216.1.90.130. | 2022-02-24 11:50:01.290
Socket (2) | Socket gracefully closed by remote side. | 2022-02-24 11:50:01.351
Socket (2) | Closed. | 2022-02-24 11:50:01.351
HD Request # 8 | Setting DTC encoding to Binary VLS | 2022-02-24 11:50:01.394
HD Request # 8 | Sending historical data logon request message. | 2022-02-24 11:50:01.394
HD Request # 8 | Requesting Intraday data. Start date-time: 2022-02-24 11:49:37. Record interval: 0. Symbol: ESH22 | 2022-02-24 11:50:01.440
HD Request # 8 | Decompressing data. | 2022-02-24 11:50:01.477
HD Request # 8 | Receiving Intraday data for F.US.EPH22 starting at 2022-02-24 11:49:37.014000 | 2022-02-24 11:50:01.480
Socket (3) | CloseSocket call. | 2022-02-24 11:50:01.485
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-02-24 11:50:01.485
Socket (3) | Socket gracefully closed by remote side. | 2022-02-24 11:50:01.524
Socket (3) | Closed. | 2022-02-24 11:50:01.524
Historical data download thread signaled to stop. | 2022-02-24 11:50:02.308
HD Request # 8 | Timestamp of first Intraday data file record written: 2022-02-24 11:49:38.124000 | 2022-02-24 11:50:02.308
HD Request # 8 | Received 817 Intraday data records from 2022-02-24 11:49:37.014000 to 2022-02-24 11:50:00.020008 (23.0 seconds) and wrote 781 records for F.US.EPH22 | 2022-02-24 11:50:02.308
HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2022-02-24 16:50:00.020008 | 2022-02-24 11:50:02.313
Added 49 Time and Sales records to Intraday data file for F.US.EPH22 after download. | 2022-02-24 11:50:02.313
HD Request # 8 | Completion time: 1s | 2022-02-24 11:50:02.314
HD Request # 8 | Intraday data download complete for F.US.EPH22. Unique request ID: 8 | 2022-02-24 11:50:02.314
Removing historical data download ID 8. | 2022-02-24 11:50:02.314
Real-time Intraday chart data file updates started for F.US.EPH22 | 2022-02-24 11:50:02.314
Intraday chart data file opened for F.US.EPH22 | 2022-02-24 11:50:02.314
HD Request # 8 | Enabling Intraday chart updating for symbol. | 2022-02-24 11:50:02.314
Triggering next historical data download in queue. | 2022-02-24 11:50:02.314
HD Request # 9 | Downloading Intraday chart data for F.US.EPM21 to the file F.US.EPM21.scid. Service: cme | 2022-02-24 11:50:02.314
HD Request # 9 | Download start date-time: 2021-06-18 09:29:59.000000. File last date-time: 2021-06-18 09:29:59.991000 | 2022-02-24 11:50:02.314
HD Request # 9 | Using server: ds21.sierracharts.com port 10149 | 2022-02-24 11:50:02.316
Socket (2) | Creating socket. | 2022-02-24 11:50:02.316
Socket (2) | New receive buffer size: 5242880 | 2022-02-24 11:50:02.316
Socket (2) | Connecting to IP: 216.1.90.129. | 2022-02-24 11:50:02.316
HD Request # 9 | Setting DTC encoding to Binary VLS | 2022-02-24 11:50:05.504
HD Request # 9 | Sending historical data logon request message. | 2022-02-24 11:50:05.504
HD Request # 9 | Requesting Intraday data. Start date-time: 2021-06-18 09:29:59. Record interval: 0. Symbol: ESM21 | 2022-02-24 11:50:05.595
HD Request # 9 | Decompressing data. | 2022-02-24 11:50:05.675
HD Request # 9 | Receiving Intraday data for F.US.EPM21 starting at 2021-06-18 09:29:59.034000 | 2022-02-24 11:50:05.677
Socket (2) | CloseSocket call. | 2022-02-24 11:50:05.677
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-02-24 11:50:05.677
Historical data download thread signaled to stop. | 2022-02-24 11:50:05.738
HD Request # 9 | Received 7 Intraday data records from 2021-06-18 09:29:59.034000 to 2021-06-18 09:29:59.991000 (1.0 seconds) and wrote 0 records for F.US.EPM21 | 2022-02-24 11:50:05.738
HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2021-06-18 13:29:59.991000 | 2022-02-24 11:50:05.739
HD Request # 9 | Completion time: 3s | 2022-02-24 11:50:05.739
HD Request # 9 | Intraday data download complete for F.US.EPM21. Unique request ID: 9 | 2022-02-24 11:50:05.739
Removing historical data download ID 9. | 2022-02-24 11:50:05.739
Real-time Intraday chart data file updates started for F.US.EPM21 | 2022-02-24 11:50:05.739
Intraday chart data file opened for F.US.EPM21 | 2022-02-24 11:50:05.739
HD Request # 9 | Enabling Intraday chart updating for symbol. | 2022-02-24 11:50:05.739
Triggering next historical data download in queue. | 2022-02-24 11:50:05.739
HD Request # 10 | Downloading Intraday chart data for F.US.ENQH22 to the file F.US.ENQH22.scid. Service: cme | 2022-02-24 11:50:05.739
HD Request # 10 | Download start date-time: 2022-02-24 11:40:53.000000. File last date-time: 2022-02-24 11:40:53.384002 | 2022-02-24 11:50:05.739
HD Request # 10 | Using server: ds23.sierracharts.com port 10150 | 2022-02-24 11:50:05.739
Socket (3) | Creating socket. | 2022-02-24 11:50:05.739
Socket (3) | New receive buffer size: 5242880 | 2022-02-24 11:50:05.739
Socket (3) | Connecting to IP: 216.1.90.130. | 2022-02-24 11:50:05.739
Socket (2) | Socket gracefully closed by remote side. | 2022-02-24 11:50:05.764
Socket (2) | Closed. | 2022-02-24 11:50:05.764
HD Request # 10 | Setting DTC encoding to Binary VLS | 2022-02-24 11:50:05.882
HD Request # 10 | Sending historical data logon request message. | 2022-02-24 11:50:05.882
HD Request # 10 | Requesting Intraday data. Start date-time: 2022-02-24 11:40:53. Record interval: 0. Symbol: NQH22 | 2022-02-24 11:50:05.925
HD Request # 10 | Decompressing data. | 2022-02-24 11:50:05.969
HD Request # 10 | Receiving Intraday data for F.US.ENQH22 starting at 2022-02-24 11:40:53.009000 | 2022-02-24 11:50:05.996
Socket (3) | CloseSocket call. | 2022-02-24 11:50:06.242
Historical data download thread signaled to stop. | 2022-02-24 11:50:06.242
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-02-24 11:50:06.242
HD Request # 10 | Timestamp of first Intraday data file record written: 2022-02-24 11:40:53.622000 | 2022-02-24 11:50:06.242
HD Request # 10 | Received 11395 Intraday data records from 2022-02-24 11:40:53.009000 to 2022-02-24 11:50:04.077001 (9.2 minutes) and wrote 11391 records for F.US.ENQH22 | 2022-02-24 11:50:06.242
HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2022-02-24 16:50:04.077001 | 2022-02-24 11:50:06.248
Added 127 Time and Sales records to Intraday data file for F.US.ENQH22 after download. | 2022-02-24 11:50:06.248
HD Request # 10 | Completion time: 1s | 2022-02-24 11:50:06.249
HD Request # 10 | Intraday data download complete for F.US.ENQH22. Unique request ID: 10 | 2022-02-24 11:50:06.249
Removing historical data download ID 10. | 2022-02-24 11:50:06.249
Real-time Intraday chart data file updates started for F.US.ENQH22 | 2022-02-24 11:50:06.249
Intraday chart data file opened for F.US.ENQH22 | 2022-02-24 11:50:06.249
HD Request # 10 | Enabling Intraday chart updating for symbol. | 2022-02-24 11:50:06.249
Triggering next historical data download in queue. | 2022-02-24 11:50:06.249
HD Request # 11 | Downloading Intraday chart data for F.US.MESH22 to the file F.US.MESH22.scid. Service: cme | 2022-02-24 11:50:06.249
HD Request # 11 | Download start date-time: 2022-02-24 11:40:52.000000. File last date-time: 2022-02-24 11:40:52.991001 | 2022-02-24 11:50:06.249
HD Request # 11 | Using server: ds21.sierracharts.com port 10149 | 2022-02-24 11:50:06.252
Socket (2) | Creating socket. | 2022-02-24 11:50:06.252
Socket (2) | New receive buffer size: 5242880 | 2022-02-24 11:50:06.252
Socket (2) | Connecting to IP: 216.1.90.129. | 2022-02-24 11:50:06.252
Socket (3) | Socket gracefully closed by remote side. | 2022-02-24 11:50:06.298
Socket (3) | Closed. | 2022-02-24 11:50:06.298
HD Request # 11 | Setting DTC encoding to Binary VLS | 2022-02-24 11:50:06.374
HD Request # 11 | Sending historical data logon request message. | 2022-02-24 11:50:06.374
HD Request # 11 | Requesting Intraday data. Start date-time: 2022-02-24 11:40:52. Record interval: 0. Symbol: MESH22 | 2022-02-24 11:50:06.435
HD Request # 11 | Decompressing data. | 2022-02-24 11:50:06.487
HD Request # 11 | Receiving Intraday data for F.US.MESH22 starting at 2022-02-24 11:40:52.031000 | 2022-02-24 11:50:06.499
Socket (2) | CloseSocket call. | 2022-02-24 11:50:06.689
Socket (2) | Shutdown started. Waiting for graceful close. | 2022-02-24 11:50:06.689
Socket (2) | Socket gracefully closed by remote side. | 2022-02-24 11:50:06.735
Socket (2) | Closed. | 2022-02-24 11:50:06.735
Historical data download thread signaled to stop. | 2022-02-24 11:50:07.486
HD Request # 11 | Timestamp of first Intraday data file record written: 2022-02-24 11:40:53.818000 | 2022-02-24 11:50:07.487
HD Request # 11 | Received 18900 Intraday data records from 2022-02-24 11:40:52.031000 to 2022-02-24 11:50:05.805000 (9.2 minutes) and wrote 18891 records for F.US.MESH22 | 2022-02-24 11:50:07.487
HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2022-02-24 16:50:05.805000 | 2022-02-24 11:50:07.491
Added 56 Time and Sales records to Intraday data file for F.US.MESH22 after download. | 2022-02-24 11:50:07.491
HD Request # 11 | Completion time: 1s | 2022-02-24 11:50:07.491
HD Request # 11 | Intraday data download complete for F.US.MESH22. Unique request ID: 11 | 2022-02-24 11:50:07.491
Removing historical data download ID 11. | 2022-02-24 11:50:07.491
Real-time Intraday chart data file updates started for F.US.MESH22 | 2022-02-24 11:50:07.491
Intraday chart data file opened for F.US.MESH22 | 2022-02-24 11:50:07.491
HD Request # 11 | Enabling Intraday chart updating for symbol. | 2022-02-24 11:50:07.491
Triggering next historical data download in queue. | 2022-02-24 11:50:07.491
No download requests in the queue to start downloads for. | 2022-02-24 11:50:07.496
Opened cached Intraday file: C:\Sierra Charts\Data\F.US.EPH22.scid. Thread ID: 308 | 2022-02-24 11:50:10.901
Opened cached Intraday file: C:\Sierra Charts\Data\F.US.ENQH22.scid. Thread ID: 308 | 2022-02-24 11:50:10.901
Opened cached Intraday file: C:\Sierra Charts\Data\F.US.MESH22.scid. Thread ID: 308 | 2022-02-24 11:50:10.901
F.US.EPH22 5 Min #16 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-01 05:25:00. Next Bar Date Time: 2022-02-01 05:20:00. Filename: F.US.EPH22.scid | 2022-02-24 11:50:32.766
F.US.EPH22 5 Min #16 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-01 05:25:00. Next Bar Date Time: 2022-02-01 05:20:00. Filename: F.US.EPH22.scid | 2022-02-24 11:50:40.237
F.US.EPH22 [CBV] 5 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-01 05:25:00. Next Bar Date Time: 2022-02-01 05:20:00. Filename: F.US.EPH22.scid | 2022-02-24 11:50:52.368
F.US.EPH22 [CBV] 5 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-01 05:25:00. Next Bar Date Time: 2022-02-01 05:20:00. Filename: F.US.EPH22.scid | 2022-02-24 11:50:55.722
F.US.EPH22 [CBV] 5 Min #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-01 05:25:00. Next Bar Date Time: 2022-02-01 05:20:00. Filename: F.US.EPH22.scid | 2022-02-24 11:50:55.854
F.US.EPH22 [CBV] 5 Min #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-01 05:25:00. Next Bar Date Time: 2022-02-01 05:20:00. Filename: F.US.EPH22.scid | 2022-02-24 11:51:00.257
F.US.EPH22 5 Min #16 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-16 05:20:00. Next Bar Date Time: 2022-02-16 05:15:00. Filename: F.US.EPH22.scid | 2022-02-24 11:51:01.792
F.US.EPH22 5 Min #16 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-16 05:20:00. Next Bar Date Time: 2022-02-16 05:15:00. Filename: F.US.EPH22.scid | 2022-02-24 11:51:07.153
F.US.EPH22 [CBV] 5 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-16 05:20:00. Next Bar Date Time: 2022-02-16 05:15:00. Filename: F.US.EPH22.scid | 2022-02-24 11:51:35.405
F.US.EPH22 [CBV] 5 Min #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-16 05:20:00. Next Bar Date Time: 2022-02-16 05:15:00. Filename: F.US.EPH22.scid | 2022-02-24 11:51:36.309
Loading market depth data. | 2022-02-24 11:51:36.622
F.US.EPH22 [CBV] 5 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-16 05:20:00. Next Bar Date Time: 2022-02-16 05:15:00. Filename: F.US.EPH22.scid | 2022-02-24 11:51:37.936
F.US.EPH22 [CBV] 5 Min #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-16 05:20:00. Next Bar Date Time: 2022-02-16 05:15:00. Filename: F.US.EPH22.scid | 2022-02-24 11:51:39.737
Loaded depth data records for F.US.MESH22 2022-02-14 from 2022-02-14 11:40:53.004000 to 2022-02-14 18:59:59.792000. | 2022-02-24 11:51:45.878
+ Loading additional symbol data. | 2022-02-24 11:51:52.785
+ Loading additional symbol data. | 2022-02-24 11:51:52.918
Loaded depth data records for F.US.MESH22 2022-02-15 from 2022-02-14 19:00:00.145000 to 2022-02-15 18:37:23.798000. | 2022-02-24 11:51:54.230
+ Loading additional symbol data. | 2022-02-24 11:51:55.721
Loaded depth data records for F.US.MESH22 2022-02-16 from 2022-02-15 19:46:52.377000 to 2022-02-16 18:59:59.856000. | 2022-02-24 11:51:56.848
+ Loading additional symbol data. | 2022-02-24 11:51:58.624
Loading market depth data. | 2022-02-24 11:51:59.946
+ Loading additional symbol data. | 2022-02-24 11:52:01.478
Loaded depth data records for F.US.MESH22 2022-02-17 from 2022-02-16 19:00:00.003000 to 2022-02-17 18:59:59.988000. | 2022-02-24 11:52:02.111
Loading market depth data. | 2022-02-24 11:52:03.291
Loaded depth data records for F.US.EPH22 2022-02-14 from 2022-02-14 11:40:53.394000 to 2022-02-14 18:59:59.792000. | 2022-02-24 11:52:04.689
F.US.MESH22 [CBV][M] 2.50 Range #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:52:05.362
Loading market depth data. | 2022-02-24 11:52:06.309
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:06.400
Loaded depth data records for F.US.MESH22 2022-02-18 from 2022-02-17 19:00:00.002000 to 2022-02-18 16:59:59.701000. | 2022-02-24 11:52:06.746
Loaded depth data records for F.US.MESH22 2022-02-19 from 2022-02-19 18:58:59.668324 to 2022-02-19 18:58:59.668324. | 2022-02-24 11:52:06.751
Loaded depth data records for F.US.MESH22 2022-02-20 from 2022-02-20 18:00:00.000000 to 2022-02-20 18:59:59.921000. | 2022-02-24 11:52:06.933
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:07.166
Loaded depth data records for F.US.MESH22 2022-02-21 from 2022-02-20 19:00:00.029000 to 2022-02-21 18:59:59.996000. | 2022-02-24 11:52:07.789
F.US.MESH22 [CBV][M] 1.25 Range #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:52:07.945
+ Loading additional symbol data. | 2022-02-24 11:52:08.721
Loading market depth data. | 2022-02-24 11:52:09.151
Loaded depth data records for F.US.EPH22 2022-02-15 from 2022-02-14 19:00:00.003000 to 2022-02-15 18:37:24.218000. | 2022-02-24 11:52:09.450
Loaded depth data records for F.US.MESH22 2022-02-23 from 2022-02-23 11:40:53.001000 to 2022-02-23 18:59:59.900000. | 2022-02-24 11:52:09.698
Loaded depth data records for F.US.MESH22 2022-02-22 from 2022-02-21 19:00:00.016000 to 2022-02-22 18:59:59.673000. | 2022-02-24 11:52:09.975
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:10.096
Loaded depth data records for F.US.MESH22 2022-02-23 from 2022-02-22 19:00:00.012000 to 2022-02-23 18:59:59.900000. | 2022-02-24 11:52:10.778
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:12.941
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:13.396
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:13.529
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:15.040
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:15.242
Loaded depth data records for F.US.EPH22 2022-02-16 from 2022-02-15 19:46:52.415000 to 2022-02-16 18:59:59.999000. | 2022-02-24 11:52:16.349
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:17.196
Loaded depth data records for F.US.MESH22 2022-02-24 from 2022-02-23 19:00:00.012000 to 2022-02-24 11:40:50.719000. | 2022-02-24 11:52:17.352
Loaded depth data records for F.US.MESH22 2022-02-24 from 2022-02-23 19:00:00.012000 to 2022-02-24 11:40:50.719000. | 2022-02-24 11:52:17.870
F.US.MESH22 [CBV][M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:52:17.943
F.US.MESH22 [CBV][M] Rev. 5t #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:52:18.237
+ Loading additional symbol data. | 2022-02-24 11:52:18.747
+ Loading additional symbol data. | 2022-02-24 11:52:21.895
Loaded depth data records for F.US.EPH22 2022-02-17 from 2022-02-16 19:00:00.002000 to 2022-02-17 18:59:59.996000. | 2022-02-24 11:52:22.177
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:22.859
F.US.MESH22 [CBV][M] 1 Min #12 | Reloading chart. | 2022-02-24 11:52:23.467
+ Loading additional symbol data. | 2022-02-24 11:52:24.403
F.US.MESH22 [CBV][M] Rev. 5t #1 | Reloading chart. | 2022-02-24 11:52:25.977
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:26.573
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:26.877
+ Loading additional symbol data. | 2022-02-24 11:52:27.508
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:27.556
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:28.096
Loaded depth data records for F.US.EPH22 2022-02-18 from 2022-02-17 19:00:00.000000 to 2022-02-18 16:59:59.700000. | 2022-02-24 11:52:29.132
Mapping F.US.USAH22 to ZBH22. Service code: cbot | 2022-02-24 11:52:29.139
SC Data - All Services | Starting real-time market data updates for: F.US.USAH22 (ZBH22). ID: 6 Service code: cbot | 2022-02-24 11:52:29.139
CQG WebAPI | Sending symbol resolution request for F.US.USAH22. ID: 184541 | 2022-02-24 11:52:29.139
SC Data - All Services | Requesting security definition data for: F.US.USAH22 (ZBH22). ID: 6 | 2022-02-24 11:52:29.139
Added historical Intraday data request for F.US.USAH22 to the queue. | 2022-02-24 11:52:29.140
Intraday data recording state for symbol F.US.USAH22 is set to download 'Pending'. | 2022-02-24 11:52:29.140
Triggering next historical data download in queue. | 2022-02-24 11:52:29.140
F.US.EPH22 [CBV][M] 5 Min #3 | Started historical data download for additional symbol F.US.USAH22. Download ID: 12 | 2022-02-24 11:52:29.140
Mapping F.US.TYAH22 to ZNH22. Service code: cbot | 2022-02-24 11:52:29.141
SC Data - All Services | Starting real-time market data updates for: F.US.TYAH22 (ZNH22). ID: 7 Service code: cbot | 2022-02-24 11:52:29.141
CQG WebAPI | Sending symbol resolution request for F.US.TYAH22. ID: 184542 | 2022-02-24 11:52:29.141
SC Data - All Services | Requesting security definition data for: F.US.TYAH22 (ZNH22). ID: 7 | 2022-02-24 11:52:29.141
Added historical Intraday data request for F.US.TYAH22 to the queue. | 2022-02-24 11:52:29.141
Intraday data recording state for symbol F.US.TYAH22 is set to download 'Pending'. | 2022-02-24 11:52:29.141
F.US.EPH22 [CBV][M] 5 Min #3 | Started historical data download for additional symbol F.US.TYAH22. Download ID: 13 | 2022-02-24 11:52:29.141
Mapping F.US.JY6H22 to 6JH22. Service code: cme | 2022-02-24 11:52:29.142
SC Data - All Services | Starting real-time market data updates for: F.US.JY6H22 (6JH22). ID: 8 Service code: cme | 2022-02-24 11:52:29.142
CQG WebAPI | Sending symbol resolution request for F.US.JY6H22. ID: 184543 | 2022-02-24 11:52:29.142
SC Data - All Services | Requesting security definition data for: F.US.JY6H22 (6JH22). ID: 8 | 2022-02-24 11:52:29.142
Added historical Intraday data request for F.US.JY6H22 to the queue. | 2022-02-24 11:52:29.142
Intraday data recording state for symbol F.US.JY6H22 is set to download 'Pending'. | 2022-02-24 11:52:29.142
F.US.EPH22 [CBV][M] 5 Min #3 | Started historical data download for additional symbol F.US.JY6H22. Download ID: 14 | 2022-02-24 11:52:29.142
SC DTC Data with Market Depth | Starting real-time market data updates for: USDX. ID: 9 Service code: fxstatscalc | 2022-02-24 11:52:29.143
SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2022-02-24 11:52:29.143
SC DTC Data with Market Depth | Requesting security definition data for: USDX. ID: 9 | 2022-02-24 11:52:29.143
Added historical Intraday data request for USDX to the queue. | 2022-02-24 11:52:29.144
Intraday data recording state for symbol USDX is set to download 'Pending'. | 2022-02-24 11:52:29.144
F.US.EPH22 [CBV][M] 5 Min #3 | Started historical data download for additional symbol USDX. Download ID: 15 | 2022-02-24 11:52:29.144
Delaying start of download for F.US.USAH22 | 2022-02-24 11:52:29.145
Loaded depth data records for F.US.EPH22 2022-02-19 from 2022-02-19 18:58:59.658715 to 2022-02-19 18:58:59.658715. | 2022-02-24 11:52:29.154
Loaded depth data records for F.US.EPH22 2022-02-20 from 2022-02-20 18:00:00.000000 to 2022-02-20 18:59:59.960000. | 2022-02-24 11:52:29.240
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:29.240
CQG WebAPI | Received symbol resolution report for symbol F.US.USAH22. Search Symbol: F.US.USAH22. Request ID: 184541. Contract ID: 5. | 2022-02-24 11:52:29.250
CQG WebAPI | Received symbol resolution report for symbol F.US.TYAH22. Search Symbol: F.US.TYAH22. Request ID: 184542. Contract ID: 6. | 2022-02-24 11:52:29.251
CQG WebAPI | Received symbol resolution report for symbol F.US.JY6H22. Search Symbol: F.US.JY6H22. Request ID: 184543. Contract ID: 7. | 2022-02-24 11:52:29.253
SC Data - All Services | Received security definition for symbol F.US.USAH22 | 2022-02-24 11:52:29.465
SC Data - All Services | Received security definition for symbol F.US.TYAH22 | 2022-02-24 11:52:29.465
SC Data - All Services | Received security definition for symbol F.US.JY6H22 | 2022-02-24 11:52:29.465
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:29.517
DTC Client socket (2) | Creating socket. | 2022-02-24 11:52:29.778
DTC Client socket (2) | New receive buffer size: 5242880 | 2022-02-24 11:52:29.778
DTC Client socket (2) | Connecting to IP: 204.15.197.14. | 2022-02-24 11:52:29.778
SC DTC Data with Market Depth | Network connection to server complete. | 2022-02-24 11:52:29.914
SC DTC Data with Market Depth | Starting socket receive thread. | 2022-02-24 11:52:29.914
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-02-24 11:52:29.914
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-02-24 11:52:30.092
SC DTC Data with Market Depth | Sending logon request message. | 2022-02-24 11:52:30.092
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:30.518
+ Loading additional symbol data. | 2022-02-24 11:52:30.654
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:30.813
SC DTC Data with Market Depth | Received logon response. | 2022-02-24 11:52:30.902
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-02-24 11:52:30.902
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-02-24 11:52:30.902
SC DTC Data with Market Depth | Successfully connected. | 2022-02-24 11:52:30.902
SC DTC Data with Market Depth | Trading is not supported. | 2022-02-24 11:52:30.902
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDX | 2022-02-24 11:52:30.902
SC DTC Data with Market Depth | Received security definition for symbol USDX | 2022-02-24 11:52:31.331
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:31.760
Loaded depth data records for F.US.EPH22 2022-02-21 from 2022-02-20 19:00:00.005000 to 2022-02-21 18:59:59.996000. | 2022-02-24 11:52:31.805
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:32.166
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:34.185
+ Loading additional symbol data. | 2022-02-24 11:52:34.464
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:34.515
+ Loading additional symbol data. | 2022-02-24 11:52:34.819
HD Request # 12 | Downloading Intraday chart data for F.US.USAH22 to the file F.US.USAH22.scid. Service: cbot | 2022-02-24 11:52:35.092
HD Request # 12 | Download start date-time: 2022-02-24 11:40:53.000000. File last date-time: 2022-02-24 11:40:53.007000 | 2022-02-24 11:52:35.221
HD Request # 12 | Using server: ds23.sierracharts.com port 10150 | 2022-02-24 11:52:35.221
Socket (3) | Creating socket. | 2022-02-24 11:52:35.221
Socket (3) | New receive buffer size: 5242880 | 2022-02-24 11:52:35.221
Socket (3) | Connecting to IP: 216.1.90.130. | 2022-02-24 11:52:35.221
HD Request # 12 | Setting DTC encoding to Binary VLS | 2022-02-24 11:52:35.298
HD Request # 12 | Sending historical data logon request message. | 2022-02-24 11:52:35.298
HD Request # 12 | Requesting Intraday data. Start date-time: 2022-02-24 11:40:53. Record interval: 0. Symbol: ZBH22 | 2022-02-24 11:52:35.789
HD Request # 12 | Decompressing data. | 2022-02-24 11:52:35.831
HD Request # 12 | Receiving Intraday data for F.US.USAH22 starting at 2022-02-24 11:40:53.007000 | 2022-02-24 11:52:35.929
Socket (3) | CloseSocket call. | 2022-02-24 11:52:35.931
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-02-24 11:52:35.931
Historical data download thread signaled to stop. | 2022-02-24 11:52:35.932
Socket (3) | Socket gracefully closed by remote side. | 2022-02-24 11:52:35.994
Socket (3) | Closed. | 2022-02-24 11:52:35.994
HD Request # 12 | Timestamp of first Intraday data file record written: 2022-02-24 11:41:07.004000 | 2022-02-24 11:52:36.252
HD Request # 12 | Received 2489 Intraday data records from 2022-02-24 11:40:53.007000 to 2022-02-24 11:52:25.008008 (11.5 minutes) and wrote 2488 records for F.US.USAH22 | 2022-02-24 11:52:36.253
HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2022-02-24 16:52:25.008008 | 2022-02-24 11:52:36.256
HD Request # 12 | Completion time: 2s | 2022-02-24 11:52:36.555
HD Request # 12 | Intraday data download complete for F.US.USAH22. Unique request ID: 12 | 2022-02-24 11:52:36.555
Removing historical data download ID 12. | 2022-02-24 11:52:36.555
Real-time Intraday chart data file updates started for F.US.USAH22 | 2022-02-24 11:52:36.555
Intraday chart data file opened for F.US.USAH22 | 2022-02-24 11:52:36.555
HD Request # 12 | Enabling Intraday chart updating for symbol. | 2022-02-24 11:52:36.555
F.US.EPH22 [CBV][M] 5 Min #3 | Historical data download for additional symbol F.US.USAH22 with ID 12 has completed. | 2022-02-24 11:52:36.555
Triggering next historical data download in queue. | 2022-02-24 11:52:36.663
HD Request # 13 | Downloading Intraday chart data for F.US.TYAH22 to the file F.US.TYAH22.scid. Service: cbot | 2022-02-24 11:52:36.663
HD Request # 13 | Download start date-time: 2022-02-24 11:40:38.000000. File last date-time: 2022-02-24 11:40:38.295000 | 2022-02-24 11:52:36.663
HD Request # 13 | Using server: ds21.sierracharts.com port 10149 | 2022-02-24 11:52:36.663
Socket (3) | Creating socket. | 2022-02-24 11:52:36.663
Socket (3) | New receive buffer size: 5242880 | 2022-02-24 11:52:36.664
Socket (3) | Connecting to IP: 216.1.90.129. | 2022-02-24 11:52:36.664
HD Request # 13 | Setting DTC encoding to Binary VLS | 2022-02-24 11:52:36.754
HD Request # 13 | Sending historical data logon request message. | 2022-02-24 11:52:36.754
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:36.870
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:37.109
HD Request # 13 | Requesting Intraday data. Start date-time: 2022-02-24 11:40:38. Record interval: 0. Symbol: ZNH22 | 2022-02-24 11:52:37.241
HD Request # 13 | Decompressing data. | 2022-02-24 11:52:37.271
HD Request # 13 | Receiving Intraday data for F.US.TYAH22 starting at 2022-02-24 11:40:38.295000 | 2022-02-24 11:52:37.443
Socket (3) | CloseSocket call. | 2022-02-24 11:52:37.447
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-02-24 11:52:37.447
Socket (3) | Socket gracefully closed by remote side. | 2022-02-24 11:52:37.484
Socket (3) | Closed. | 2022-02-24 11:52:37.484
Historical data download thread signaled to stop. | 2022-02-24 11:52:37.667
HD Request # 13 | Timestamp of first Intraday data file record written: 2022-02-24 11:41:04.185000 | 2022-02-24 11:52:38.028
HD Request # 13 | Received 4998 Intraday data records from 2022-02-24 11:40:38.295000 to 2022-02-24 11:52:34.508021 (11.9 minutes) and wrote 4997 records for F.US.TYAH22 | 2022-02-24 11:52:38.028
HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2022-02-24 16:52:34.508021 | 2022-02-24 11:52:38.156
Added 3 Time and Sales records to Intraday data file for F.US.TYAH22 after download. | 2022-02-24 11:52:38.289
HD Request # 13 | Completion time: 2s | 2022-02-24 11:52:38.290
HD Request # 13 | Intraday data download complete for F.US.TYAH22. Unique request ID: 13 | 2022-02-24 11:52:38.290
Removing historical data download ID 13. | 2022-02-24 11:52:38.290
Real-time Intraday chart data file updates started for F.US.TYAH22 | 2022-02-24 11:52:38.290
Intraday chart data file opened for F.US.TYAH22 | 2022-02-24 11:52:38.290
HD Request # 13 | Enabling Intraday chart updating for symbol. | 2022-02-24 11:52:38.290
F.US.EPH22 [CBV][M] 5 Min #3 | Historical data download for additional symbol F.US.TYAH22 with ID 13 has completed. | 2022-02-24 11:52:38.290
Triggering next historical data download in queue. | 2022-02-24 11:52:38.290
HD Request # 14 | Downloading Intraday chart data for F.US.JY6H22 to the file F.US.JY6H22.scid. Service: cme | 2022-02-24 11:52:38.290
HD Request # 14 | Download start date-time: 2022-02-24 11:40:47.000000. File last date-time: 2022-02-24 11:40:47.853000 | 2022-02-24 11:52:38.290
HD Request # 14 | Using server: ds23.sierracharts.com port 10150 | 2022-02-24 11:52:38.290
Socket (3) | Creating socket. | 2022-02-24 11:52:38.290
Socket (3) | New receive buffer size: 5242880 | 2022-02-24 11:52:38.290
Socket (3) | Connecting to IP: 216.1.90.130. | 2022-02-24 11:52:38.290
HD Request # 14 | Setting DTC encoding to Binary VLS | 2022-02-24 11:52:38.441
HD Request # 14 | Sending historical data logon request message. | 2022-02-24 11:52:38.441
HD Request # 14 | Requesting Intraday data. Start date-time: 2022-02-24 11:40:47. Record interval: 0. Symbol: 6JH22 | 2022-02-24 11:52:38.528
HD Request # 14 | Decompressing data. | 2022-02-24 11:52:38.591
HD Request # 14 | Receiving Intraday data for F.US.JY6H22 starting at 2022-02-24 11:40:47.848000 | 2022-02-24 11:52:38.600
Socket (3) | CloseSocket call. | 2022-02-24 11:52:38.629
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-02-24 11:52:38.629
Socket (3) | Socket gracefully closed by remote side. | 2022-02-24 11:52:38.681
Socket (3) | Closed. | 2022-02-24 11:52:38.681
Loaded depth data records for F.US.EPH22 2022-02-22 from 2022-02-21 19:00:00.058000 to 2022-02-22 18:59:59.769000. | 2022-02-24 11:52:38.763
Historical data download thread signaled to stop. | 2022-02-24 11:52:39.487
HD Request # 14 | Timestamp of first Intraday data file record written: 2022-02-24 11:41:01.088000 | 2022-02-24 11:52:39.573
HD Request # 14 | Received 1145 Intraday data records from 2022-02-24 11:40:47.848000 to 2022-02-24 11:52:37.333000 (11.8 minutes) and wrote 1137 records for F.US.JY6H22 | 2022-02-24 11:52:39.573
HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2022-02-24 16:52:37.333000 | 2022-02-24 11:52:39.576
HD Request # 14 | Completion time: 1s | 2022-02-24 11:52:39.601
HD Request # 14 | Intraday data download complete for F.US.JY6H22. Unique request ID: 14 | 2022-02-24 11:52:39.601
Removing historical data download ID 14. | 2022-02-24 11:52:39.601
Real-time Intraday chart data file updates started for F.US.JY6H22 | 2022-02-24 11:52:39.601
Intraday chart data file opened for F.US.JY6H22 | 2022-02-24 11:52:39.601
HD Request # 14 | Enabling Intraday chart updating for symbol. | 2022-02-24 11:52:39.601
F.US.EPH22 [CBV][M] 5 Min #3 | Historical data download for additional symbol F.US.JY6H22 with ID 14 has completed. | 2022-02-24 11:52:39.601
Triggering next historical data download in queue. | 2022-02-24 11:52:39.601
HD Request # 15 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc | 2022-02-24 11:52:39.602
HD Request # 15 | Download start date-time: 2022-02-24 11:40:53.000000. File last date-time: 2022-02-24 11:40:53.000000 | 2022-02-24 11:52:39.609
HD Request # 15 | Using server: ds12.sierracharts.com port 10149 | 2022-02-24 11:52:39.609
+ Loading additional symbol data. | 2022-02-24 11:52:39.729
Socket (3) | Creating socket. | 2022-02-24 11:52:39.807
Socket (3) | New receive buffer size: 5242880 | 2022-02-24 11:52:39.807
Socket (3) | Connecting to IP: 204.15.197.14. | 2022-02-24 11:52:39.807
HD Request # 15 | Setting DTC encoding to Binary VLS | 2022-02-24 11:52:39.938
HD Request # 15 | Sending historical data logon request message. | 2022-02-24 11:52:39.938
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:40.427
HD Request # 15 | Requesting Intraday data. Start date-time: 2022-02-24 11:40:53. Record interval: 0. Symbol: USDX | 2022-02-24 11:52:40.555
HD Request # 15 | Decompressing data. | 2022-02-24 11:52:40.591
HD Request # 15 | Receiving Intraday data for USDX starting at 2022-02-24 11:40:53.000000 | 2022-02-24 11:52:40.597
Socket (3) | CloseSocket call. | 2022-02-24 11:52:40.636
Socket (3) | Shutdown started. Waiting for graceful close. | 2022-02-24 11:52:40.636
Socket (3) | Socket gracefully closed by remote side. | 2022-02-24 11:52:40.676
Socket (3) | Closed. | 2022-02-24 11:52:40.676
Historical data download thread signaled to stop. | 2022-02-24 11:52:40.701
HD Request # 15 | Timestamp of first Intraday data file record written: 2022-02-24 11:40:54.000000 | 2022-02-24 11:52:40.803
HD Request # 15 | Received 705 Intraday data records from 2022-02-24 11:40:53.000000 to 2022-02-24 11:52:38.000000 (11.8 minutes) and wrote 704 records for USDX | 2022-02-24 11:52:40.803
HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2022-02-24 16:52:38.000000 | 2022-02-24 11:52:40.808
Added 4 Time and Sales records to Intraday data file for USDX after download. | 2022-02-24 11:52:40.808
HD Request # 15 | Completion time: 1s | 2022-02-24 11:52:40.809
HD Request # 15 | Intraday data download complete for USDX. Unique request ID: 15 | 2022-02-24 11:52:40.809
Removing historical data download ID 15. | 2022-02-24 11:52:40.809
Real-time Intraday chart data file updates started for USDX | 2022-02-24 11:52:40.809
Intraday chart data file opened for USDX | 2022-02-24 11:52:40.809
HD Request # 15 | Enabling Intraday chart updating for symbol. | 2022-02-24 11:52:40.809
F.US.EPH22 [CBV][M] 5 Min #3 | Historical data download for additional symbol USDX with ID 15 has completed. | 2022-02-24 11:52:40.809
Triggering next historical data download in queue. | 2022-02-24 11:52:40.916
No download requests in the queue to start downloads for. | 2022-02-24 11:52:40.916
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:41.949
F.US.EPH22 [CBV][M] 5 Min #3 | Reloading chart. | 2022-02-24 11:52:42.153
Loaded depth data records for F.US.EPH22 2022-02-23 from 2022-02-22 19:00:00.003000 to 2022-02-23 18:59:59.980000. | 2022-02-24 11:52:42.373
Loading market depth data. | 2022-02-24 11:52:43.049
F.US.EPH22 [CBV][M] 1.25 Range #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:52:43.105
+ Loading additional symbol data. | 2022-02-24 11:52:43.645
Loaded depth data records for F.US.EPH22 2022-02-24 from 2022-02-23 19:00:00.003000 to 2022-02-24 11:40:50.742000. | 2022-02-24 11:52:45.159
Opened cached Intraday file: C:\Sierra Charts\Data\F.US.USAH22.scid. Thread ID: 308 | 2022-02-24 11:52:45.545
Opened cached Intraday file: C:\Sierra Charts\Data\F.US.TYAH22.scid. Thread ID: 308 | 2022-02-24 11:52:45.546
Opened cached Intraday file: C:\Sierra Charts\Data\F.US.JY6H22.scid. Thread ID: 308 | 2022-02-24 11:52:45.546
Opened cached Intraday file: C:\Sierra Charts\Data\USDX.scid. Thread ID: 308 | 2022-02-24 11:52:45.546
F.US.EPH22 [CBV][M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:52:45.694
Loading market depth data. | 2022-02-24 11:52:45.864
Loading market depth data. | 2022-02-24 11:52:45.897
F.US.EPH22 [CBV][M] 2.50 Range #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:52:46.046
Loaded depth data records for F.US.EPH22 2022-02-23 from 2022-02-23 11:40:53.385000 to 2022-02-23 18:59:59.980000. | 2022-02-24 11:52:46.797
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:47.249
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:47.889
F.US.EPH22 [CBV][M] 1 Min #12 | Reloading chart. | 2022-02-24 11:52:48.977
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:49.596
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:50.058
+ Loading additional symbol data. | 2022-02-24 11:52:50.848
Loaded depth data records for F.US.EPH22 2022-02-24 from 2022-02-23 19:00:00.003000 to 2022-02-24 11:40:50.742000. | 2022-02-24 11:52:50.874
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:50.934
F.US.EPH22 [CBV][M] Rev. 5t #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:52:51.058
F.US.EPH22 [CBV] 5 Min #20 | Reloading chart. | 2022-02-24 11:52:52.909
F.US.EPH22 [CBV] 5 Min #3 | Reloading chart. | 2022-02-24 11:52:53.183
F.US.ENQH22 [CBV] 2.50 Range #5 | Reloading chart. | 2022-02-24 11:52:53.289
F.US.EPM21 240 Min #18 | Reloading chart. | 2022-02-24 11:52:53.857
F.US.MESH22 [CBV] 5.00 Range #2 | Reloading chart. | 2022-02-24 11:52:54.034
F.US.EPH22 2.50 Range #33 | Reloading chart. | 2022-02-24 11:52:54.784
F.US.EPH22 1 Min #19 | Reloading chart. | 2022-02-24 11:52:55.311
F.US.EPH22 1 Min #14 | Reloading chart. | 2022-02-24 11:52:55.519
F.US.EPH22 60 Min #6 | Reloading chart. | 2022-02-24 11:52:55.543
F.US.MESH22 [CBV] 1.25 Range #4 | Reloading chart. | 2022-02-24 11:52:55.558
F.US.EPZ21 1 Min #13 | Reloading chart. | 2022-02-24 11:52:57.330
F.US.EPH22 5 Min #16 | Reloading chart. | 2022-02-24 11:52:57.949
F.US.EPZ21 5 Min #9 | Reloading chart. | 2022-02-24 11:52:58.421
F.US.MESH22 [CBV] Rev. 5t #1 | Reloading chart. | 2022-02-24 11:52:59.261
F.US.MESH22 [CBV] 1 Min #12 | Reloading chart. | 2022-02-24 11:53:01.682
F.US.MESH22 [CBV] #10 | Reloading chart. | 2022-02-24 11:53:04.074
F.US.MESH22 [CBV] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:53:04.792
Mapping F.US.EU6H22 to 6EH22. Service code: cme | 2022-02-24 11:53:05.258
SC Data - All Services | Starting real-time market data updates for: F.US.EU6H22 (6EH22). ID: 10 Service code: cme | 2022-02-24 11:53:05.258
CQG WebAPI | Sending symbol resolution request for F.US.EU6H22. ID: 184544 | 2022-02-24 11:53:05.258
SC Data - All Services | Requesting security definition data for: F.US.EU6H22 (6EH22). ID: 10 | 2022-02-24 11:53:05.258
Added historical Intraday data request for F.US.EU6H22 to the queue. | 2022-02-24 11:53:05.258
Intraday data recording state for symbol F.US.EU6H22 is set to download 'Pending'. | 2022-02-24 11:53:05.258
Triggering next historical data download in queue. | 2022-02-24 11:53:05.258
F.US.EPH22 [CBV][M] 5 Min #20 | Started historical data download for additional symbol F.US.EU6H22. Download ID: 16 | 2022-02-24 11:53:05.258
Mapping F.US.YMH22 to YMH22. Service code: cbot | 2022-02-24 11:53:05.258
SC Data - All Services | Starting real-time market data updates for: F.US.YMH22 (YMH22). ID: 11 Service code: cbot | 2022-02-24 11:53:05.258
CQG WebAPI | Sending symbol resolution request for F.US.YMH22. ID: 184545 | 2022-02-24 11:53:05.258
SC Data - All Services | Requesting security definition data for: F.US.YMH22 (YMH22). ID: 11 | 2022-02-24 11:53:05.259
Added historical Intraday data request for F.US.YMH22 to the queue. | 2022-02-24 11:53:05.259
Intraday data recording state for symbol F.US.YMH22 is set to download 'Pending'. | 2022-02-24 11:53:05.259
F.US.EPH22 [CBV][M] 5 Min #20 | Started historical data download for additional symbol F.US.YMH22. Download ID: 17 | 2022-02-24 11:53:05.259
Mapping F.US.RTYH22 to RTYH22. Service code: cme | 2022-02-24 11:53:05.259
SC Data - All Services | Starting real-time market data updates for: F.US.RTYH22 (RTYH22). ID: 12 Service code: cme | 2022-02-24 11:53:05.259
CQG WebAPI | Sending symbol resolution request for F.US.RTYH22. ID: 184546 | 2022-02-24 11:53:05.259
SC Data - All Services | Requesting security definition data for: F.US.RTYH22 (RTYH22). ID: 12 | 2022-02-24 11:53:05.259
Added historical Intraday data request for F.US.RTYH22 to the queue. | 2022-02-24 11:53:05.259
Intraday data recording state for symbol F.US.RTYH22 is set to download 'Pending'. | 2022-02-24 11:53:05.259
F.US.EPH22 [CBV][M] 5 Min #20 | Started historical data download for additional symbol F.US.RTYH22. Download ID: 18 | 2022-02-24 11:53:05.259
Delaying start of download for F.US.EU6H22 | 2022-02-24 11:53:05.272
CQG WebAPI | Received symbol resolution report for symbol F.US.EU6H22. Search Symbol: F.US.EU6H22. Request ID: 184544. Contract ID: 8. | 2022-02-24 11:53:05.480
CQG WebAPI | Received symbol resolution report for symbol F.US.YMH22. Search Symbol: F.US.YMH22. Request ID: 184545. Contract ID: 9. | 2022-02-24 11:53:05.481
CQG WebAPI | Received symbol resolution report for symbol F.US.RTYH22. Search Symbol: F.US.RTYH22. Request ID: 184546. Contract ID: 10. | 2022-02-24 11:53:05.481
SC Data - All Services | Received security definition for symbol F.US.EU6H22 | 2022-02-24 11:53:05.485
SC Data - All Services | Received security definition for symbol F.US.YMH22 | 2022-02-24 11:53:05.485
SC Data - All Services | Received security definition for symbol F.US.RTYH22 | 2022-02-24 11:53:05.485
F.US.EPH22 [CBV][M] Rev. 5t #1 | Reloading chart. | 2022-02-24 11:53:08.077
HD Request # 16 | Downloading Intraday chart data for F.US.EU6H22 to the file F.US.EU6H22.scid. Service: cme | 2022-02-24 11:53:17.022
HD Request # 16 | Download start date-time: 2022-02-24 11:40:52.000000. File last date-time: 2022-02-24 11:40:52.673000 | 2022-02-24 11:53:17.022
HD Request # 16 | Using server: ds21.sierracharts.com port 10150 | 2022-02-24 11:53:17.022
Socket (4) | Creating socket. | 2022-02-24 11:53:17.022
Socket (4) | New receive buffer size: 5242880 | 2022-02-24 11:53:17.022
Socket (4) | Connecting to IP: 216.1.90.129. | 2022-02-24 11:53:17.022
HD Request # 16 | Setting DTC encoding to Binary VLS | 2022-02-24 11:53:17.207
HD Request # 16 | Sending historical data logon request message. | 2022-02-24 11:53:17.207
HD Request # 16 | Requesting Intraday data. Start date-time: 2022-02-24 11:40:52. Record interval: 0. Symbol: 6EH22 | 2022-02-24 11:53:17.883
HD Request # 16 | Decompressing data. | 2022-02-24 11:53:17.941
HD Request # 16 | Receiving Intraday data for F.US.EU6H22 starting at 2022-02-24 11:40:52.673000 | 2022-02-24 11:53:17.944
Socket (4) | CloseSocket call. | 2022-02-24 11:53:18.023
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-02-24 11:53:18.023
Socket (4) | Socket gracefully closed by remote side. | 2022-02-24 11:53:18.058
Socket (4) | Closed. | 2022-02-24 11:53:18.058
Historical data download thread signaled to stop. | 2022-02-24 11:53:18.392
HD Request # 16 | Timestamp of first Intraday data file record written: 2022-02-24 11:40:54.076000 | 2022-02-24 11:53:18.392
HD Request # 16 | Received 2912 Intraday data records from 2022-02-24 11:40:52.673000 to 2022-02-24 11:53:09.625002 (12.3 minutes) and wrote 2911 records for F.US.EU6H22 | 2022-02-24 11:53:18.392
HD Request # 16 | Add time&sales data | Remembered last file record date-time: 2022-02-24 16:53:09.625002 | 2022-02-24 11:53:18.411
Added 5 Time and Sales records to Intraday data file for F.US.EU6H22 after download. | 2022-02-24 11:53:18.411
HD Request # 16 | Completion time: 1s | 2022-02-24 11:53:18.411
HD Request # 16 | Intraday data download complete for F.US.EU6H22. Unique request ID: 16 | 2022-02-24 11:53:18.411
Removing historical data download ID 16. | 2022-02-24 11:53:18.411
Real-time Intraday chart data file updates started for F.US.EU6H22 | 2022-02-24 11:53:18.411
Intraday chart data file opened for F.US.EU6H22 | 2022-02-24 11:53:18.411
HD Request # 16 | Enabling Intraday chart updating for symbol. | 2022-02-24 11:53:18.411
F.US.EPH22 [CBV][M] 5 Min #20 | Historical data download for additional symbol F.US.EU6H22 with ID 16 has completed. | 2022-02-24 11:53:18.411
Triggering next historical data download in queue. | 2022-02-24 11:53:18.411
HD Request # 17 | Downloading Intraday chart data for F.US.YMH22 to the file F.US.YMH22.scid. Service: cbot | 2022-02-24 11:53:18.411
HD Request # 17 | Download start date-time: 2022-02-24 11:40:52.000000. File last date-time: 2022-02-24 11:40:52.179000 | 2022-02-24 11:53:18.411
HD Request # 17 | Using server: ds23.sierracharts.com port 10149 | 2022-02-24 11:53:18.411
Socket (4) | Creating socket. | 2022-02-24 11:53:18.411
Socket (4) | New receive buffer size: 5242880 | 2022-02-24 11:53:18.411
Socket (4) | Connecting to IP: 216.1.90.130. | 2022-02-24 11:53:18.411
HD Request # 17 | Setting DTC encoding to Binary VLS | 2022-02-24 11:53:18.523
HD Request # 17 | Sending historical data logon request message. | 2022-02-24 11:53:18.523
HD Request # 17 | Requesting Intraday data. Start date-time: 2022-02-24 11:40:52. Record interval: 0. Symbol: YMH22 | 2022-02-24 11:53:19.020
HD Request # 17 | Decompressing data. | 2022-02-24 11:53:19.056
HD Request # 17 | Receiving Intraday data for F.US.YMH22 starting at 2022-02-24 11:40:52.179000 | 2022-02-24 11:53:19.098
Socket (4) | CloseSocket call. | 2022-02-24 11:53:19.148
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-02-24 11:53:19.148
Socket (4) | Socket gracefully closed by remote side. | 2022-02-24 11:53:19.181
Socket (4) | Closed. | 2022-02-24 11:53:19.181
Historical data download thread signaled to stop. | 2022-02-24 11:53:19.195
HD Request # 17 | Timestamp of first Intraday data file record written: 2022-02-24 11:40:53.533000 | 2022-02-24 11:53:19.218
HD Request # 17 | Received 4613 Intraday data records from 2022-02-24 11:40:52.179000 to 2022-02-24 11:53:16.919002 (12.4 minutes) and wrote 4612 records for F.US.YMH22 | 2022-02-24 11:53:19.218
HD Request # 17 | Add time&sales data | Remembered last file record date-time: 2022-02-24 16:53:16.919002 | 2022-02-24 11:53:19.223
Added 14 Time and Sales records to Intraday data file for F.US.YMH22 after download. | 2022-02-24 11:53:19.339
HD Request # 17 | Completion time: 1s | 2022-02-24 11:53:19.339
HD Request # 17 | Intraday data download complete for F.US.YMH22. Unique request ID: 17 | 2022-02-24 11:53:19.339
Removing historical data download ID 17. | 2022-02-24 11:53:19.339
Real-time Intraday chart data file updates started for F.US.YMH22 | 2022-02-24 11:53:19.339
Intraday chart data file opened for F.US.YMH22 | 2022-02-24 11:53:19.339
HD Request # 17 | Enabling Intraday chart updating for symbol. | 2022-02-24 11:53:19.339
F.US.EPH22 [CBV][M] 5 Min #20 | Historical data download for additional symbol F.US.YMH22 with ID 17 has completed. | 2022-02-24 11:53:19.339
Triggering next historical data download in queue. | 2022-02-24 11:53:19.339
HD Request # 18 | Downloading Intraday chart data for F.US.RTYH22 to the file F.US.RTYH22.scid. Service: cme | 2022-02-24 11:53:19.339
HD Request # 18 | Download start date-time: 2022-02-24 11:40:52.000000. File last date-time: 2022-02-24 11:40:52.136000 | 2022-02-24 11:53:19.342
HD Request # 18 | Using server: ds21.sierracharts.com port 10150 | 2022-02-24 11:53:19.342
Socket (4) | Creating socket. | 2022-02-24 11:53:19.342
Socket (4) | New receive buffer size: 5242880 | 2022-02-24 11:53:19.342
Socket (4) | Connecting to IP: 216.1.90.129. | 2022-02-24 11:53:19.342
HD Request # 18 | Setting DTC encoding to Binary VLS | 2022-02-24 11:53:19.421
HD Request # 18 | Sending historical data logon request message. | 2022-02-24 11:53:19.421
HD Request # 18 | Requesting Intraday data. Start date-time: 2022-02-24 11:40:52. Record interval: 0. Symbol: RTYH22 | 2022-02-24 11:53:19.454
HD Request # 18 | Decompressing data. | 2022-02-24 11:53:19.499
HD Request # 18 | Receiving Intraday data for F.US.RTYH22 starting at 2022-02-24 11:40:52.136000 | 2022-02-24 11:53:19.738
Socket (4) | CloseSocket call. | 2022-02-24 11:53:19.742
Socket (4) | Shutdown started. Waiting for graceful close. | 2022-02-24 11:53:19.742
Historical data download thread signaled to stop. | 2022-02-24 11:53:19.742
Socket (4) | Socket gracefully closed by remote side. | 2022-02-24 11:53:19.773
Socket (4) | Closed. | 2022-02-24 11:53:19.774
HD Request # 18 | Timestamp of first Intraday data file record written: 2022-02-24 11:40:54.226000 | 2022-02-24 11:53:21.068
HD Request # 18 | Received 4361 Intraday data records from 2022-02-24 11:40:52.136000 to 2022-02-24 11:53:18.668000 (12.4 minutes) and wrote 4360 records for F.US.RTYH22 | 2022-02-24 11:53:21.068
HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2022-02-24 16:53:18.668000 | 2022-02-24 11:53:21.754
Added 7 Time and Sales records to Intraday data file for F.US.RTYH22 after download. | 2022-02-24 11:53:21.754
HD Request # 18 | Completion time: 2s | 2022-02-24 11:53:21.755
HD Request # 18 | Intraday data download complete for F.US.RTYH22. Unique request ID: 18 | 2022-02-24 11:53:21.755
Removing historical data download ID 18. | 2022-02-24 11:53:21.755
Real-time Intraday chart data file updates started for F.US.RTYH22 | 2022-02-24 11:53:21.755
Intraday chart data file opened for F.US.RTYH22 | 2022-02-24 11:53:21.755
HD Request # 18 | Enabling Intraday chart updating for symbol. | 2022-02-24 11:53:21.755
F.US.EPH22 [CBV][M] 5 Min #20 | Historical data download for additional symbol F.US.RTYH22 with ID 18 has completed. | 2022-02-24 11:53:21.755
Triggering next historical data download in queue. | 2022-02-24 11:53:21.755
No download requests in the queue to start downloads for. | 2022-02-24 11:53:21.756
F.US.EPH22 [CBV][M] 5 Min #20 | Reloading chart. | 2022-02-24 11:53:21.757
Opened cached Intraday file: C:\Sierra Charts\Data\F.US.YMH22.scid. Thread ID: 308 | 2022-02-24 11:53:22.628
Opened cached Intraday file: C:\Sierra Charts\Data\F.US.EU6H22.scid. Thread ID: 308 | 2022-02-24 11:53:35.873
Opened cached Intraday file: C:\Sierra Charts\Data\F.US.RTYH22.scid. Thread ID: 308 | 2022-02-24 11:53:35.873
Loading market depth data. | 2022-02-24 11:53:49.099
F.US.EPH22 [CBV][M] 5 Min #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-01 05:25:00. Next Bar Date Time: 2022-02-01 05:20:00. Filename: F.US.EPH22.scid | 2022-02-24 11:53:56.443
Loaded depth data records for F.US.MESH22 2022-02-14 from 2022-02-14 11:52:17.416000 to 2022-02-14 18:59:59.792000. | 2022-02-24 11:53:56.729
Loaded depth data records for F.US.MESH22 2022-02-15 from 2022-02-14 19:00:00.145000 to 2022-02-15 18:37:23.798000. | 2022-02-24 11:54:06.521
F.US.EPH22 [CBV] 5 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-01 05:25:00. Next Bar Date Time: 2022-02-01 05:20:00. Filename: F.US.EPH22.scid | 2022-02-24 11:54:12.104
Loaded depth data records for F.US.MESH22 2022-02-16 from 2022-02-15 19:46:52.377000 to 2022-02-16 18:59:59.856000. | 2022-02-24 11:54:14.698
F.US.EPH22 [CBV] 5 Min #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-01 05:25:00. Next Bar Date Time: 2022-02-01 05:20:00. Filename: F.US.EPH22.scid | 2022-02-24 11:54:17.069
F.US.EPH22 [CBV][M] 5 Min #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-16 05:20:00. Next Bar Date Time: 2022-02-16 05:15:00. Filename: F.US.EPH22.scid | 2022-02-24 11:54:22.091
Loaded depth data records for F.US.MESH22 2022-02-17 from 2022-02-16 19:00:00.003000 to 2022-02-17 18:59:59.988000. | 2022-02-24 11:54:22.694
F.US.EPH22 5 Min #16 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-01 05:25:00. Next Bar Date Time: 2022-02-01 05:20:00. Filename: F.US.EPH22.scid | 2022-02-24 11:54:26.927
Loading market depth data. | 2022-02-24 11:54:30.665
Loaded depth data records for F.US.MESH22 2022-02-23 from 2022-02-23 11:52:23.426000 to 2022-02-23 18:59:59.900000. | 2022-02-24 11:54:31.341
Loaded depth data records for F.US.MESH22 2022-02-18 from 2022-02-17 19:00:00.002000 to 2022-02-18 16:59:59.701000. | 2022-02-24 11:54:32.192
Loaded depth data records for F.US.MESH22 2022-02-19 from 2022-02-19 18:58:59.668324 to 2022-02-19 18:58:59.668324. | 2022-02-24 11:54:32.193
Loaded depth data records for F.US.MESH22 2022-02-20 from 2022-02-20 18:00:00.000000 to 2022-02-20 18:59:59.921000. | 2022-02-24 11:54:32.253
Loaded depth data records for F.US.MESH22 2022-02-21 from 2022-02-20 19:00:00.029000 to 2022-02-21 18:59:59.996000. | 2022-02-24 11:54:35.423
Loaded depth data records for F.US.MESH22 2022-02-24 from 2022-02-23 19:00:00.012000 to 2022-02-24 11:52:23.423000. | 2022-02-24 11:54:36.965
F.US.MESH22 [CBV][M] Rev. 5t #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:54:37.326
Loaded depth data records for F.US.MESH22 2022-02-22 from 2022-02-21 19:00:00.016000 to 2022-02-22 18:59:59.673000. | 2022-02-24 11:54:39.617
F.US.EPH22 [CBV] 5 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-16 05:20:00. Next Bar Date Time: 2022-02-16 05:15:00. Filename: F.US.EPH22.scid | 2022-02-24 11:54:39.765
Loading market depth data. | 2022-02-24 11:54:39.950
+ Loading additional symbol data. | 2022-02-24 11:54:40.572
Loaded depth data records for F.US.MESH22 2022-02-23 from 2022-02-22 19:00:00.012000 to 2022-02-23 18:59:59.900000. | 2022-02-24 11:54:42.823
F.US.EPH22 [CBV][M] 5 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-01 05:25:00. Next Bar Date Time: 2022-02-01 05:20:00. Filename: F.US.EPH22.scid | 2022-02-24 11:54:45.027
Loaded depth data records for F.US.MESH22 2022-02-14 from 2022-02-14 11:53:01.625000 to 2022-02-14 18:59:59.792000. | 2022-02-24 11:54:45.632
Loaded depth data records for F.US.MESH22 2022-02-24 from 2022-02-23 19:00:00.012000 to 2022-02-24 11:52:17.415000. | 2022-02-24 11:54:47.356
F.US.MESH22 [CBV][M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:54:47.936
+ Loading additional symbol data. | 2022-02-24 11:54:49.252
F.US.EPH22 [CBV] 5 Min #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-16 05:20:00. Next Bar Date Time: 2022-02-16 05:15:00. Filename: F.US.EPH22.scid | 2022-02-24 11:54:51.555
Loaded depth data records for F.US.MESH22 2022-02-15 from 2022-02-14 19:00:00.145000 to 2022-02-15 18:37:23.798000. | 2022-02-24 11:54:52.059
F.US.EPH22 5 Min #16 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-16 05:20:00. Next Bar Date Time: 2022-02-16 05:15:00. Filename: F.US.EPH22.scid | 2022-02-24 11:54:52.549
Loaded depth data records for F.US.MESH22 2022-02-16 from 2022-02-15 19:46:52.377000 to 2022-02-16 18:59:59.856000. | 2022-02-24 11:54:57.015
Loading market depth data. | 2022-02-24 11:54:58.109
F.US.MESH22 [CBV][M] 5.00 Range #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:54:59.186
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:54:59.268
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:54:59.864
+ Loading additional symbol data. | 2022-02-24 11:54:59.989
+ Loading additional symbol data. | 2022-02-24 11:55:02.145
Loading market depth data. | 2022-02-24 11:55:02.263
Loaded depth data records for F.US.MESH22 2022-02-17 from 2022-02-16 19:00:00.003000 to 2022-02-17 18:59:59.988000. | 2022-02-24 11:55:02.465
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:03.745
Loaded depth data records for F.US.EPH22 2022-02-14 from 2022-02-14 11:52:44.665000 to 2022-02-14 18:59:59.792000. | 2022-02-24 11:55:06.401
+ Loading additional symbol data. | 2022-02-24 11:55:06.831
Loaded depth data records for F.US.MESH22 2022-02-18 from 2022-02-17 19:00:00.002000 to 2022-02-18 16:59:59.701000. | 2022-02-24 11:55:07.935
Loaded depth data records for F.US.MESH22 2022-02-19 from 2022-02-19 18:58:59.668324 to 2022-02-19 18:58:59.668324. | 2022-02-24 11:55:07.935
Loaded depth data records for F.US.MESH22 2022-02-20 from 2022-02-20 18:00:00.000000 to 2022-02-20 18:59:59.921000. | 2022-02-24 11:55:08.099
Loading market depth data. | 2022-02-24 11:55:08.785
Loaded depth data records for F.US.MESH22 2022-02-21 from 2022-02-20 19:00:00.029000 to 2022-02-21 18:59:59.996000. | 2022-02-24 11:55:09.356
Loaded depth data records for F.US.EPH22 2022-02-15 from 2022-02-14 19:00:00.003000 to 2022-02-15 18:37:24.218000. | 2022-02-24 11:55:09.433
F.US.MESH22 [CBV][M] 1.25 Range #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:55:09.773
+ Loading additional symbol data. | 2022-02-24 11:55:10.336
Loaded depth data records for F.US.MESH22 2022-02-22 from 2022-02-21 19:00:00.016000 to 2022-02-22 18:59:59.673000. | 2022-02-24 11:55:11.350
F.US.EPH22 [CBV][M] 5 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-16 05:20:00. Next Bar Date Time: 2022-02-16 05:15:00. Filename: F.US.EPH22.scid | 2022-02-24 11:55:11.753
Loaded depth data records for F.US.MESH22 2022-02-23 from 2022-02-22 19:00:00.012000 to 2022-02-23 18:59:59.900000. | 2022-02-24 11:55:12.076
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:12.452
Loaded depth data records for F.US.EPH22 2022-02-16 from 2022-02-15 19:46:52.415000 to 2022-02-16 18:59:59.999000. | 2022-02-24 11:55:14.242
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:14.291
Loading market depth data. | 2022-02-24 11:55:15.003
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:15.433
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:15.640
Loaded depth data records for F.US.MESH22 2022-02-23 from 2022-02-23 11:52:55.175000 to 2022-02-23 18:59:59.900000. | 2022-02-24 11:55:15.775
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:15.906
Loaded depth data records for F.US.MESH22 2022-02-24 from 2022-02-23 19:00:00.012000 to 2022-02-24 11:53:01.623000. | 2022-02-24 11:55:15.918
F.US.MESH22 [CBV][M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:55:16.040
+ Loading additional symbol data. | 2022-02-24 11:55:16.674
Loaded depth data records for F.US.EPH22 2022-02-17 from 2022-02-16 19:00:00.002000 to 2022-02-17 18:59:59.996000. | 2022-02-24 11:55:18.265
Loaded depth data records for F.US.MESH22 2022-02-24 from 2022-02-23 19:00:00.012000 to 2022-02-24 11:52:55.029000. | 2022-02-24 11:55:18.329
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:24.808
+ Loading additional symbol data. | 2022-02-24 11:55:25.074
+ Loading additional symbol data. | 2022-02-24 11:55:26.908
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:27.244
F.US.MESH22 [CBV][M] Rev. 5t #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:55:27.530
+ Loading additional symbol data. | 2022-02-24 11:55:29.012
Loaded depth data records for F.US.EPH22 2022-02-18 from 2022-02-17 19:00:00.000000 to 2022-02-18 16:59:59.700000. | 2022-02-24 11:55:29.776
Loaded depth data records for F.US.EPH22 2022-02-19 from 2022-02-19 18:58:59.658715 to 2022-02-19 18:58:59.658715. | 2022-02-24 11:55:29.776
Loaded depth data records for F.US.EPH22 2022-02-20 from 2022-02-20 18:00:00.000000 to 2022-02-20 18:59:59.960000. | 2022-02-24 11:55:29.835
+ Loading additional symbol data. | 2022-02-24 11:55:31.494
Loaded depth data records for F.US.EPH22 2022-02-21 from 2022-02-20 19:00:00.005000 to 2022-02-21 18:59:59.996000. | 2022-02-24 11:55:32.297
+ Loading additional symbol data. | 2022-02-24 11:55:35.596
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:36.281
Loaded depth data records for F.US.EPH22 2022-02-22 from 2022-02-21 19:00:00.058000 to 2022-02-22 18:59:59.769000. | 2022-02-24 11:55:38.428
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:38.507
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:39.268
Loaded depth data records for F.US.EPH22 2022-02-23 from 2022-02-22 19:00:00.003000 to 2022-02-23 18:59:59.980000. | 2022-02-24 11:55:42.402
+ Loading additional symbol data. | 2022-02-24 11:55:42.910
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:46.377
Loading market depth data. | 2022-02-24 11:55:46.393
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:47.869
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:48.091
Loaded depth data records for F.US.EPH22 2022-02-23 from 2022-02-23 11:53:01.704000 to 2022-02-23 18:59:59.980000. | 2022-02-24 11:55:48.177
+ Loading additional symbol data. | 2022-02-24 11:55:48.206
Loaded depth data records for F.US.EPH22 2022-02-24 from 2022-02-23 19:00:00.003000 to 2022-02-24 11:52:44.654000. | 2022-02-24 11:55:48.562
F.US.EPH22 [CBV][M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:55:49.132
F.US.MESH22 [CBV][M] 1 Min #12 | Reloading chart. | 2022-02-24 11:55:49.320
F.US.MESH22 [CBV][M] Rev. 5t #1 | Reloading chart. | 2022-02-24 11:55:49.610
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:50.097
+ Loading additional symbol data. | 2022-02-24 11:55:50.478
Loaded depth data records for F.US.EPH22 2022-02-24 from 2022-02-23 19:00:00.003000 to 2022-02-24 11:53:01.679000. | 2022-02-24 11:55:51.012
F.US.EPH22 [CBV][M] Rev. 5t #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:55:51.138
+ Loading additional symbol data. | 2022-02-24 11:55:55.799
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:57.505
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:57.746
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:57.908
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:57.941
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:57.990
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:55:59.290
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:05.597
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:06.529
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:06.772
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:11.271
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:11.518
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:12.382
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:17.412
Loading market depth data. | 2022-02-24 11:56:17.891
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:18.684
Loaded depth data records for F.US.MESH22 2022-02-14 from 2022-02-14 11:55:42.592000 to 2022-02-14 18:59:59.792000. | 2022-02-24 11:56:21.689
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:22.577
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:23.121
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:23.723
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:23.854
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:24.406
Loaded depth data records for F.US.MESH22 2022-02-15 from 2022-02-14 19:00:00.145000 to 2022-02-15 18:37:23.798000. | 2022-02-24 11:56:24.751
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:24.751
Loading market depth data. | 2022-02-24 11:56:24.953
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:25.180
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:25.331
Loaded depth data records for F.US.MESH22 2022-02-23 from 2022-02-23 11:55:42.637000 to 2022-02-23 18:59:59.900000. | 2022-02-24 11:56:25.376
Loaded depth data records for F.US.MESH22 2022-02-16 from 2022-02-15 19:46:52.377000 to 2022-02-16 18:59:59.856000. | 2022-02-24 11:56:28.439
Loaded depth data records for F.US.MESH22 2022-02-24 from 2022-02-23 19:00:00.012000 to 2022-02-24 11:55:42.587000. | 2022-02-24 11:56:28.941
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:30.342
F.US.MESH22 [CBV][M] Rev. 5t #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:56:30.422
Loaded depth data records for F.US.MESH22 2022-02-17 from 2022-02-16 19:00:00.003000 to 2022-02-17 18:59:59.988000. | 2022-02-24 11:56:30.763
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:31.758
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:32.034
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:32.147
Loaded depth data records for F.US.MESH22 2022-02-18 from 2022-02-17 19:00:00.002000 to 2022-02-18 16:59:59.701000. | 2022-02-24 11:56:33.444
Loaded depth data records for F.US.MESH22 2022-02-19 from 2022-02-19 18:58:59.668324 to 2022-02-19 18:58:59.668324. | 2022-02-24 11:56:33.445
Loaded depth data records for F.US.MESH22 2022-02-20 from 2022-02-20 18:00:00.000000 to 2022-02-20 18:59:59.921000. | 2022-02-24 11:56:33.489
Loaded depth data records for F.US.MESH22 2022-02-21 from 2022-02-20 19:00:00.029000 to 2022-02-21 18:59:59.996000. | 2022-02-24 11:56:34.641
Loaded depth data records for F.US.MESH22 2022-02-22 from 2022-02-21 19:00:00.016000 to 2022-02-22 18:59:59.673000. | 2022-02-24 11:56:36.029
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:36.067
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:36.402
Loaded depth data records for F.US.MESH22 2022-02-23 from 2022-02-22 19:00:00.012000 to 2022-02-23 18:59:59.900000. | 2022-02-24 11:56:36.566
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:36.958
Array message repeat count limit reached. | 2022-02-24 11:56:36.958
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:37.066
Loaded depth data records for F.US.MESH22 2022-02-24 from 2022-02-23 19:00:00.012000 to 2022-02-24 11:55:42.587000. | 2022-02-24 11:56:39.734
F.US.MESH22 [CBV][M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:56:41.018
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:41.250
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:41.666
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:56:42.046
Array message repeat count limit reached. | 2022-02-24 11:56:42.046
F.US.MESH22 [CBV][M] Rev. 5t #1 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 11:56:55.556
F.US.MESH22 [CBV][M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 11:56:55.563
F.US.EPH22 [CBV][M] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:56:55.580
F.US.MESH22 [CBV][M] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:56:55.705
F.US.EPH22 [CBV][M] Rev. 5t #1 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 11:56:55.715
F.US.MESH22 [CBV][M] 5.00 Range #2 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 11:56:55.741
F.US.EPH22 [CBV][M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 11:56:55.784
F.US.MESH22 [CBV][M] 2.50 Range #2 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 11:56:55.787
F.US.MESH22 [CBV][M] Rev. 5t #1 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 11:56:55.793
F.US.MESH22 [CBV][M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 11:56:55.804
F.US.EPH22 [CBV][M] 1.25 Range #4 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 11:56:55.825
F.US.MESH22 [CBV][M] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 11:56:55.853
F.US.EPH22 [CBV][M] 2.50 Range #2 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 11:56:55.859
F.US.MESH22 [CBV][M] 1.25 Range #4 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 11:56:55.864
F.US.MESH22 [CBV][M] 1.25 Range #4 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 11:56:55.908
F.US.MESH22 [CBV][M] 5.00 Range #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:01:10.444
F.US.EPH22 [CBV][M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:01:10.606
F.US.MESH22 [CBV][M] 2.50 Range #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:01:10.629
F.US.MESH22 [CBV][M] Rev. 5t #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:01:10.832
F.US.MESH22 [CBV][M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:01:11.269
F.US.EPH22 [CBV][M] 1.25 Range #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:01:11.275
F.US.MESH22 [CBV][M] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:01:12.082
F.US.EPH22 [CBV][M] 2.50 Range #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:01:12.086
F.US.MESH22 [CBV][M] 1.25 Range #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:01:12.274
F.US.MESH22 [CBV][M] 1.25 Range #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:01:12.861
F.US.MESH22 [CBV][M] Rev. 5t #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:01:16.360
F.US.MESH22 [CBV][M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:01:16.819
F.US.EPH22 [CBV][M] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:01:17.027
F.US.MESH22 [CBV][M] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:01:17.273
F.US.EPH22 [CBV][M] Rev. 5t #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:01:17.297
F.US.MESH22 [CBV][M] 5.00 Range #2 | Reloading chart. | 2022-02-24 12:26:04.681
Loading market depth data. | 2022-02-24 12:26:08.648
F.US.MESH22 [CBV][M] 5.00 Range #2 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:26:08.653
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:08.708
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:08.755
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:08.787
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:17.773
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:23.832
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:29.637
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:33.338
F.US.MESH22 [CBV][M] 1.25 Range #4 | Reloading chart. | 2022-02-24 12:26:39.315
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:39.509
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:40.127
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:40.541
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:41.038
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:41.544
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:42.022
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:42.519
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:43.020
Loading market depth data. | 2022-02-24 12:26:43.272
F.US.MESH22 [CBV][M] 1.25 Range #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:26:43.275
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:43.395
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:43.508
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:43.567
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:43.652
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:44.012
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:44.099
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:44.352
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:44.533
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:44.854
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:45.046
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:45.354
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:45.467
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:45.518
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:45.553
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:45.587
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:45.620
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:45.650
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:45.681
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:45.711
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:45.744
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:45.775
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:45.905
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:45.988
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:46.025
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:46.060
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:46.089
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:46.118
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:46.194
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:46.305
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:46.347
Chart #4 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:46.423
Array message repeat count limit reached. | 2022-02-24 12:26:46.423
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:46.600
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:47.090
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:47.606
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 12:26:48.177
Array message repeat count limit reached. | 2022-02-24 12:26:48.177
F.US.MESH22 [CBV][M] Rev. 5t #1 | Reloading chart. | 2022-02-24 12:27:48.418
Loading market depth data. | 2022-02-24 12:27:51.250
Loaded depth data records for F.US.MESH22 2022-02-23 from 2022-02-23 12:27:46.364000 to 2022-02-23 18:59:59.900000. | 2022-02-24 12:27:51.454
Loaded depth data records for F.US.MESH22 2022-02-24 from 2022-02-23 19:00:00.012000 to 2022-02-24 12:27:46.211000. | 2022-02-24 12:27:52.623
F.US.MESH22 [CBV][M] Rev. 5t #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:27:52.625
F.US.MESH22 [CBV][M] 1 Min #12 | Reloading chart. | 2022-02-24 12:28:03.615
Loading market depth data. | 2022-02-24 12:28:05.337
Loaded depth data records for F.US.MESH22 2022-02-14 from 2022-02-14 18:00:00.000000 to 2022-02-14 18:59:59.792000. | 2022-02-24 12:28:05.359
Loaded depth data records for F.US.MESH22 2022-02-15 from 2022-02-14 19:00:00.145000 to 2022-02-15 18:37:23.798000. | 2022-02-24 12:28:06.708
Loaded depth data records for F.US.MESH22 2022-02-16 from 2022-02-15 19:46:52.377000 to 2022-02-16 18:59:59.856000. | 2022-02-24 12:28:07.780
Loaded depth data records for F.US.MESH22 2022-02-17 from 2022-02-16 19:00:00.003000 to 2022-02-17 18:59:59.988000. | 2022-02-24 12:28:09.180
Loaded depth data records for F.US.MESH22 2022-02-18 from 2022-02-17 19:00:00.002000 to 2022-02-18 16:59:59.701000. | 2022-02-24 12:28:10.876
Loaded depth data records for F.US.MESH22 2022-02-19 from 2022-02-19 18:58:59.668324 to 2022-02-19 18:58:59.668324. | 2022-02-24 12:28:10.876
Loaded depth data records for F.US.MESH22 2022-02-20 from 2022-02-20 18:00:00.000000 to 2022-02-20 18:59:59.921000. | 2022-02-24 12:28:10.921
Loaded depth data records for F.US.MESH22 2022-02-21 from 2022-02-20 19:00:00.029000 to 2022-02-21 18:59:59.996000. | 2022-02-24 12:28:11.374
Loaded depth data records for F.US.MESH22 2022-02-22 from 2022-02-21 19:00:00.016000 to 2022-02-22 18:59:59.673000. | 2022-02-24 12:28:11.942
Loaded depth data records for F.US.MESH22 2022-02-23 from 2022-02-22 19:00:00.012000 to 2022-02-23 18:59:59.900000. | 2022-02-24 12:28:12.223
Loaded depth data records for F.US.MESH22 2022-02-24 from 2022-02-23 19:00:00.012000 to 2022-02-24 12:28:01.547000. | 2022-02-24 12:28:13.068
F.US.MESH22 [CBV][M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:28:13.069
F.US.MESH22 [CBV][M] #10 | Reloading chart. | 2022-02-24 12:28:27.100
F.US.MESH22 [CBV][M] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:28:27.112
F.US.EPH22 [CBV][M] 5 Min #20 | Reloading chart. | 2022-02-24 12:28:42.535
F.US.EPH22 [CBV][M] 1 Min #12 | Reloading chart. | 2022-02-24 12:28:42.737
F.US.EPH22 [CBV][M] Rev. 5t #1 | Reloading chart. | 2022-02-24 12:28:42.763
F.US.EPH22 [CBV][M] 5 Min #20 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-16 05:20:00. Next Bar Date Time: 2022-02-16 05:15:00. Filename: F.US.EPH22.scid | 2022-02-24 12:28:43.204
+ Loading additional symbol data. | 2022-02-24 12:28:47.187
Loading market depth data. | 2022-02-24 12:28:47.860
Loaded depth data records for F.US.EPH22 2022-02-14 from 2022-02-14 18:00:00.000000 to 2022-02-14 18:59:59.792000. | 2022-02-24 12:28:47.967
+ Loading additional symbol data. | 2022-02-24 12:28:49.141
+ Loading additional symbol data. | 2022-02-24 12:28:49.343
+ Loading additional symbol data. | 2022-02-24 12:28:50.240
Loading market depth data. | 2022-02-24 12:28:50.319
Loaded depth data records for F.US.EPH22 2022-02-15 from 2022-02-14 19:00:00.003000 to 2022-02-15 18:37:24.218000. | 2022-02-24 12:28:51.205
Loaded depth data records for F.US.EPH22 2022-02-23 from 2022-02-23 12:28:42.005000 to 2022-02-23 18:59:59.980000. | 2022-02-24 12:28:51.728
Loaded depth data records for F.US.EPH22 2022-02-16 from 2022-02-15 19:46:52.415000 to 2022-02-16 18:59:59.999000. | 2022-02-24 12:28:53.811
Loaded depth data records for F.US.EPH22 2022-02-24 from 2022-02-23 19:00:00.003000 to 2022-02-24 12:28:42.004000. | 2022-02-24 12:28:55.003
F.US.EPH22 [CBV][M] Rev. 5t #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:28:55.014
Loaded depth data records for F.US.EPH22 2022-02-17 from 2022-02-16 19:00:00.002000 to 2022-02-17 18:59:59.996000. | 2022-02-24 12:28:55.799
Loaded depth data records for F.US.EPH22 2022-02-18 from 2022-02-17 19:00:00.000000 to 2022-02-18 16:59:59.700000. | 2022-02-24 12:28:57.739
Loaded depth data records for F.US.EPH22 2022-02-19 from 2022-02-19 18:58:59.658715 to 2022-02-19 18:58:59.658715. | 2022-02-24 12:28:57.739
Loaded depth data records for F.US.EPH22 2022-02-20 from 2022-02-20 18:00:00.000000 to 2022-02-20 18:59:59.960000. | 2022-02-24 12:28:57.797
Loaded depth data records for F.US.EPH22 2022-02-21 from 2022-02-20 19:00:00.005000 to 2022-02-21 18:59:59.996000. | 2022-02-24 12:28:58.417
F.US.EPH22 [CBV][M] 5 Min #3 | Reloading chart. | 2022-02-24 12:28:59.456
F.US.EPH22 [CBV][M] 5 Min #3 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-16 05:20:00. Next Bar Date Time: 2022-02-16 05:15:00. Filename: F.US.EPH22.scid | 2022-02-24 12:28:59.884
Loaded depth data records for F.US.EPH22 2022-02-22 from 2022-02-21 19:00:00.058000 to 2022-02-22 18:59:59.769000. | 2022-02-24 12:29:01.488
Loaded depth data records for F.US.EPH22 2022-02-23 from 2022-02-22 19:00:00.003000 to 2022-02-23 18:59:59.980000. | 2022-02-24 12:29:03.106
+ Loading additional symbol data. | 2022-02-24 12:29:03.324
+ Loading additional symbol data. | 2022-02-24 12:29:03.692
+ Loading additional symbol data. | 2022-02-24 12:29:04.638
+ Loading additional symbol data. | 2022-02-24 12:29:04.780
Loaded depth data records for F.US.EPH22 2022-02-24 from 2022-02-23 19:00:00.003000 to 2022-02-24 12:28:42.004000. | 2022-02-24 12:29:05.513
F.US.EPH22 [CBV][M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:29:05.519
F.US.EPH22[M] 5 Min #9 | Reloading chart. | 2022-02-24 12:30:03.095
F.US.EPH22[M] 5 Min #9 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2022-02-16 05:20:00. Next Bar Date Time: 2022-02-16 05:15:00. Filename: F.US.EPH22.scid | 2022-02-24 12:30:03.469
F.US.ENQH22 [CBV][M] 2.50 Range #5 | Reloading chart. | 2022-02-24 12:30:17.477
F.US.ENQH22 [CBV][M] Rev. 5t #1 | Reloading chart. | 2022-02-24 12:30:18.007
F.US.ENQH22 [CBV][M] 1 Min #12 | Reloading chart. | 2022-02-24 12:30:18.492
Requesting market depth updates for: F.US.ENQH22 if supported. | 2022-02-24 12:30:19.040
Opened cached Depth file: C:\Sierra Charts\Data\MarketDepthData\F.US.ENQH22.2022-02-24.depth | 2022-02-24 12:30:19.394
SC Data - All Services | Clearing market depth for F.US.ENQH22 | 2022-02-24 12:30:19.400
F.US.EPH22[M] 60 Min #6 | Reloading chart. | 2022-02-24 12:30:29.915
Loading market depth data. | 2022-02-24 12:30:30.778
Enabling compression for file: C:\Sierra Charts\Data\MarketDepthData\F.US.ENQH22.2022-02-24.depth. This may take a while. | 2022-02-24 12:30:31.436
File compression enabled. C:\Sierra Charts\Data\MarketDepthData\F.US.ENQH22.2022-02-24.depth. CompressionState=0 | 2022-02-24 12:30:31.436
Loaded depth data records for F.US.ENQH22 2022-02-24 from 00:00:00.000000 to 00:00:00.000000. | 2022-02-24 12:30:31.440
F.US.ENQH22 [CBV][M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:30:31.454
Loading market depth data. | 2022-02-24 12:30:38.364
Loaded depth data records for F.US.ENQH22 2022-02-24 from 00:00:00.000000 to 00:00:00.000000. | 2022-02-24 12:30:38.380
F.US.ENQH22 [CBV][M] Rev. 5t #1 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:30:38.381
F.US.EPH22 [CBV][M] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:32:16.473
F.US.EPH22 [CBV][M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 2022-02-10 12:32:15 | 2022-02-24 12:32:16.491
F.US.MESH22 [CBV][M] 2.50 Range #2 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 12:32:16.507
F.US.EPH22 [CBV][M] 1.25 Range #4 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 12:32:16.517
F.US.MESH22 [CBV][M] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:32:16.539
F.US.EPH22 [CBV][M] 2.50 Range #2 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 12:32:16.541
F.US.MESH22 [CBV][M] 1.25 Range #4 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 12:32:16.546
F.US.MESH22 [CBV][M] 5.00 Range #2 | StartDateTimeForLoadingOrderFills: 2022-02-10 12:32:15 | 2022-02-24 12:32:16.570
F.US.ENQH22 [CBV][M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 12:32:16.605
F.US.ENQH22 [CBV][M] Rev. 5t #1 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 12:32:16.611
F.US.MESH22 [CBV][M] #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-02-24 12:32:16.839
F.US.MESH22 [CBV][M] Rev. 5t #1 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 12:32:16.845
F.US.MESH22 [CBV][M] 1 Min #12 | StartDateTimeForLoadingOrderFills: 2021-12-26 18:00:00 | 2022-02-24 12:32:16.849
F.US.EPH22 [CBV][M] Rev. 5t #1 | StartDateTimeForLoadingOrderFills: 2022-02-10 12:32:16 | 2022-02-24 12:32:16.852
F.US.MESH22 [CBV][M] 1.25 Range #4 | StartDateTimeForLoadingOrderFills: 2022-02-10 12:32:16 | 2022-02-24 12:32:16.868
[2022-02-24 18:16:24]
John - SC Support - Posts: 38516
Your log is not showing any particular lag or connection issues. So please go through the information in Help Topic 30 and see if something there might help.
But, we do see the following in your log:
Chart #2 | Base Graph ID: 0 SubGraphData Array3: Out of bounds array error at Index 0 | 2022-02-24 11:52:06.400
It is not something to be concerned about, but we would like to get your Chartbook for us to see if we can reproduce this. Follow these instructions to attach your Chartbook:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2022-02-24 18:31:36]
Are you using a hard drive, or a solid-state drive? Use a solid-state drive:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.29 - Solid State Drives / SSD
Also refer to:
Chart Trading and the Chart DOM: Improving Performance Of Chart / Trade DOM
Date Time Of Last Edit: 2022-02-24 18:32:10
