Date/Time: Tue, 04 Mar 2025 15:17:17 +0000
Any way to remotely disconnect Sierrachart
View Count: 634
[2021-12-17 09:40:28]
User339987 - Posts: 14
I lost the ability to connect to a remote PC which has an instance of Sierra Chart running,
Is there any way to disable that connection remotely?
Does Sierra Chart checking login credential periodically? If so, I can change my password in the account control panel then it will not able to connect.
Thank you very much.
[2021-12-17 15:28:26]
John - SC Support - Posts: 38344
There is not a way to disable Sierra Chart remotely. You would need to get access to that system again, somehow, in order to stop Sierra Chart.
