Date/Time: Tue, 04 Mar 2025 14:45:45 +0000
Switching to SC/CME Futures Order Routing FROM SC/TT
View Count: 582
[2021-12-17 00:41:10]
Mercrastius - Posts: 45
I just downloaded the latest version of SierraChart and would like to switch to the SierraChart CME Futures order routing. I currently have Denali with the TT Futures order routing. I'm with Stage 5 and clear thru Advantage.
Is it just a matter of making the change in the Data/Trade Service settings, or does my broker need to get involved somehow?
Thanks,
Mike
[2021-12-17 03:34:30]
You need to ask your broker to do this. Please ask them as soon as possible. We want to get users off of TT as soon as possible.
Instructions are here:
[2021-12-17 14:56:32]
This has been completed. Thanks
[2021-12-17 15:43:59]
John - SC Support - Posts: 38341
Just to make sure you are aware that after your broker has you setup on the new service, you will need to then update your Sierra Chart Data/Trade Service Settings. Refer to the Setup Instructions for the Teton Order Routing Service at the following link:
Sierra Chart Teton Futures Order Routing: Setup Instructions
In your case, you will just need to start with Step #6, since your broker already has you setup and you have the Denali Exchange Data Feed.
