Date/Time: Tue, 08 Sep 2026 23:27:37 +0000
OneUp Trader
View Count: 1061
[2021-12-16 21:33:52]
User347150 - Posts: 29
Can I use my current subscription with Sierra Charts with OneUp Trader, by signing out of my credential with Amp Futures and replacing those credentials with the credential for OneUp Trader ?
[2021-12-16 22:05:53]
John - SC Support - Posts: 47806
You can, but it not the recommended method for doing this.
It is a lot better to have 2 separate installations of Sierra Chart, one for your AMP account and the other for your OneUp account. Refer to the following for how install a second Sierra Chart:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
If you no longer have an AMP account, then you could just change the service settings on the one installation.
In either case, you would need to follow the instructions to connect to your OneUp account. We assume that OneUp is using Rithmic, in which case you would follow these instructions to connect your Sierra Chart to Rithmic:
Rithmic Trading Platform Service: Setup Instructions
