Date/Time: Tue, 04 Mar 2025 15:21:51 +0000
Intraday data storage Unit - changing resolution
View Count: 561
[2021-12-16 18:31:10] |
User92573 - Posts: 547 |
Dear Support Due to changes in my trading strategy I've changed my Intraday data storage Unit from 1 minute to tick (now need a higher resolution). Can anyone answer the following re the SCID data file: 1) Will the Tick Data only be recorded from the time of the change? 2) How far back will Sierra Chart go to download Tick data? 3) Do I need to delete and rebuild the current data file and if so will I loose the use of my many years of 1 minute date? 4) Is the Tick file a different file to the 1 Minute SCID? 4) Once set to Tick , as opposed to 1 minute. Will Sierra continue to record and update missing tick data indefinitely? I anyone can help with these questions it would be appreciated. Many thanks |
[2021-12-16 19:02:24] |
All of these questions are answered here: Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings) And here: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxHistoricalIntradayDaysToDownload Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-16 19:03:18
