Date/Time: Wed, 23 Sep 2026 07:33:06 +0000
Just activated Denali - updating every 5 seconds
View Count: 1099
[2021-12-16 18:05:31]
User933209 - Posts: 47
Signed all agreements, they were accepted. I am using CQG WebAPI but using sierra chart data is on in common settings of data/trading services. But data (charts, DOM) are updating in very slow.
[2021-12-16 18:45:53]
Any solution? Everything worked fine in the past months of using Sierra chart. And when I activated Denali today it is super slow at updating.
[2021-12-16 19:16:56]
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
[2021-12-16 19:28:04]
I copied the log from my main Instance. But all of my instances are the same - slow.
[2021-12-16 23:22:51]
Everything looks fine in this Message Log. Provide us the heartbeat messages as explained here:
Prices / Data Falling Behind: 4.17 - Providing Heartbeat Messages to Sierra Chart Support
When Sierra Chart is connected and after you have enabled the heartbeat messages, wait about a minute before providing them.
Date Time Of Last Edit: 2021-12-16 23:23:20
[2021-12-17 13:58:01]
Update: Changed to standard compression (high compression before) - 100 Milliseconds. Tad bit better. But no where near close how it was.
[2021-12-17 14:39:37]
High compression is fine.
So did you set this to 100 ms?:
https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#RemoteBufferDelaySendTimeInMilliseconds
This will be fine. We were going to recommend to reduce it.
Also check the Chart Update Interval:
Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu)
Date Time Of Last Edit: 2021-12-17 14:41:31
[2021-12-17 18:13:53]
Hello - I would really like to fix this ASAP. Wasn't able to trade yesterday as well as today. It is currently on standard compression - 100. Chart Interval - 10ms. Chart interval has always been 10ms working perfectly fine.
Please and thank you.
[2021-12-18 02:30:09]
Sierra_Chart Engineering - Posts: 24945
This is very unusual. It is not a problem that we ever hear about. Close all of the charts except for one chart. See if you still notice the issue with that one chart.
[2021-12-20 13:18:51]
Yes, still fairly jumpy updates.
[2021-12-20 20:40:44]
We just tried calling so we can have a look at this. However, we got voicemail.
