Date/Time: Tue, 04 Mar 2025 15:19:34 +0000
Opening a Custom Chartbook
View Count: 547
[2021-12-16 17:57:54]
Cobinhas - Posts: 4
I have a custom chartbook, but when I open it with Sierra Charts, about 8 or 9 charts should open, and only 4 do.
The TPO charts do not open to me, nor those of Order Flow, nor those of Delta.
Any help you can provide on this?
[2021-12-16 18:47:18]
John - SC Support - Posts: 38345
Sometimes these charts are off to the side of the screen or detached and are not readily visible. The easiest solution is to go to the CW menu and select the chart you are looking for - you should be able then see at least a part of that chart on your screen. You may need to then move it to see it completely.
[2021-12-16 19:52:39]
Cobinhas - Posts: 4
Could someone help me with a remote to configure my templates?
[2021-12-16 21:49:21]
This is not something we have the time to do. We recommend contacting Diana Pena who is someone that we know that gives Sierra Chart help at a reasonable fee. You can contact her at the following link:
https://bio.link/dianapena
[2021-12-16 22:00:19]
What you want to do is select Window >> Cascade. And for any chart you do not see, then go to the CW menu and select it from there and then select Window >> Maximize.
We will add this to the documentation.
