Date/Time: Tue, 04 Mar 2025 14:57:08 +0000
Returning to AMP futures
View Count: 761
[2021-12-16 17:35:30]
User654138 - Posts: 27
I am switching from Transact back to Amp, I can't seem to connect data/trading feeds. I contacted Amp and they told me I needed to notify Sierra support. Where can I find the instructions to connect rhythmic data to amp.
Thanks,
Vern Kelly
[2021-12-16 18:30:20]
John - SC Support - Posts: 38341
We assume that you are setup to use Rithmic for your order routing with AMP given your last statement. If this is correct, then you will follow these instructions to setup your Sierra Chart to connect to your Rithmic account:
Rithmic Trading Platform Service: Setup Instructions
[2021-12-16 21:45:23]
I followed the attached instructions, the login info I have for rithmic is from last year when you switched support to Sierra support only, username is spotlessjag@amp.com. I keep getting the following error message. Amp's trade desk says they are I am listed as Sierracharts Delali but showing no data.
Thanks,
Vern
Date Time Of Last Edit: 2021-12-17 04:58:01
Private File
[2021-12-16 22:08:26]
The main thing is that you need to get connected to your Rithmic account.
We do not believe that what you are using is your correct Rithmic account name. We have never seen an email used for the account name in the past. Please check with AMP to verify your Rithmic credentials and then re-enter them on the Data/Trade Service Settings window.
[2021-12-16 22:14:56]
I think I've got it, I had to enter the CQG routing info, it appears to be working
