Date/Time: Tue, 04 Mar 2025 15:19:18 +0000
section on website for hotkey integration/setup?
View Count: 469
[2021-12-16 16:07:18] |
HeyUgly - Posts: 251 |
hello inside sierra, how can i setup hotkeys properly ie - assign a key command - 5 contracts buy on ask - flatten and cancel - sell 5 contracts into bid etc ive looked around alot and have not been able to figure this out yet thanks in advance for any direction on website to configure this |
[2021-12-16 18:01:47] |
John - SC Support - Posts: 38345 |
The general information for setting up Keyboard Shortcuts is here: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) You can not setup a single key to do "set a quantity of 5 and buy on Ask". But you can set the quantity in one and buy on ask on another. Also, be aware of the Trading Configurations, which can help you get to a particular setup quicker. Refer to the following: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-16 18:53:46] |
oh yes for sure id be looking at setting up 10-15 hotkeys thanks ill have a look! |
