Date/Time: Tue, 04 Mar 2025 15:05:28 +0000
Replay Feature Denali
View Count: 751
[2021-12-16 15:04:58] |
User529087 - Posts: 25 |
Hi, Concerning the replay: 1. Is the replay feature using the Denali feed on replay data? 2. Will the MBO be available on replay? All the DOM data? 3. I need to replay the month of December. and see the Dom with all the prices and fluctuations possible with the Denali feed for the month of December on the NQ how do I do that? 4.Should I record the data during the day? or don't need to? How can I get the maximum level of accuracy on the DOM while replaying the past? 5. Does it work on cryptocurrencies too? 6. When I tried to replay it wasn't loading or was not working correctly or the chart was running but the Dom was not displaying any orders, what did i miss? |
[2021-12-16 17:32:47] |
John - SC Support - Posts: 38341 |
1. We are not sure what exactly you are asking here. The replay is using whatever data has been recorded for the chart. So if you are using the Denali Exchange Data Feed for your data, then the replay is going to use that same data. 2. The MBO data is not available during a replay, but the Market Depth is. Refer to the following for how to replay the Market Depth: Replaying Charts: Replaying of Market Depth Data 3. Refer to the instructions for replay here (and note what we mentioned in item #2 above): Replaying Charts 4. Refer to item #2 above. Note that if you are using the Market Depth Historical Graph, then the data is automatically recorded, but it is best to set the Symbol Settings to record the market depth nonetheless. Also, there is historical market depth data available. Refer to the following: Market Depth Historical Graph: Downloading Of Historical Market Depth Data 5. If the market depth data is being sent, then all the above applies to Cryptocurrencies. 6. Refer to the items we mentioned above first. Also, if you are replaying a Trading DOM, then refer to the following: Replaying Charts: Replaying Trade DOM Windows For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
