Date/Time: Tue, 04 Mar 2025 15:14:10 +0000
Attached stop loss issue
View Count: 546
[2021-12-16 14:55:02]
User98657 - Posts: 341
I noticed an issue trading in SIM this morning and need help figuring it out.
If I place a buy order by Left clicking below the market I see my Entry, my attached targets, and my attached stop and all are correct. If, however, I Left click above the market using that same trade configuration with attached orders I get immediately stopped. I've tried several times, on different charts with different markets and different trade configurations and all of them are acting the same.
Also, if I Left click below the market on a buy order, then drag that buy order up above the market, the stop order is not where it should be. In this case, just for example, I'm using a 20 tick stop, but when I do what I just explained I get a 2 tick stop order placement.
I only switched to sim today to work out some issues. I don't recall this being an issue last week in live trading and I have not upgraded since last week (Version 2333, Revision 40167).
To clarify:
My Chart DOM settings when I Left click above Buy Column is to Buy Limit.
Left click below market = Buy Limit
Right click above market = Buy Stop
It almost feels like the attached stop order is reacting to the mouse click.
Any help or guidance is appreciated.
Date Time Of Last Edit: 2021-12-16 15:03:25
[2021-12-16 15:02:58]
This has been fixed and it affects, Trade Simulation Mode when Sierra Chart is set to the SC CME Futures Order Routing service. Update to the current version:
And also make sure this option and the next option are enabled:
Global Trade Settings Windows: Adjust Attached Orders to Maintain Same Offset on Parent Fill (Global Settings >> General Trade Settings >> General)
Date Time Of Last Edit: 2021-12-16 15:04:14
