Date/Time: Tue, 04 Mar 2025 14:56:11 +0000
Issue: Chart data and profile issues on continuous CL contract rollover
View Count: 550
[2021-12-16 14:00:54]
User21243 - Posts: 48
Never had this happen before.
Have it set on continuous contract volume based rollover.
Chart data and profiles were fine before rolling it over see pic "1_before"
After rolling it over:
12/15 was last correct date on chart and profiles
New dates of 11/4- 12/15 are being added to the chart (after the correct 12/15 day) without profiles and all additional data is being combined into one profile on right. -- See pic " 1_after2.
Same thing is happening on my other cl RTH chart. 12/15 last correct day and new days of 12/1 - 12/15 are being added to it -- profile combined on the right -- see pic "1_after3"
Tried deleting and re-downloading data (12/13 - current), and then all of RTH chart data range history and the issue is still happening.
My ETH cl charts (also continuous volume based rollover) are fine.
Thanks.
image1_before.png / V - Attached On 2021-12-16 13:58:52 UTC - Size: 32.74 KB - 147 views
image1_after2.png / V - Attached On 2021-12-16 13:59:09 UTC - Size: 153.85 KB - 149 views
image1_after3.png / V - Attached On 2021-12-16 13:59:18 UTC - Size: 86.63 KB - 145 views
[2021-12-16 14:49:45]
We are not observing any issue ourselves:
https://www.sierrachart.com/image.php?Image=1639666156148.png
Follow the instructions here and re-download the data for the last 3 contract months:
[2021-12-16 15:12:08]
Redid something last week and added a new sub instance, and somehow had "Use Custom Symbol Settings Values" checked.
Unchecked it and deleted last 3 contract month data and now it's all good.
Thanks.
