Date/Time: Tue, 04 Mar 2025 15:14:46 +0000
Activation
View Count: 439
[2021-12-16 13:47:50] |
User976943 - Posts: 39 |
Good Morning In order to activate and use my account with my transact account as before this break, Do I need just to make the payment of $26us? Is there something else to do? Thank You |
[2021-12-16 17:10:29] |
John - SC Support - Posts: 38344 |
Right now your account is active with Package 3 and you have Usage Time through January 16, 2022. As long as you did not make any changes to your Data/Trade Service Settings, then you should still be connected to your TransAct account and you should be fine. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
