Date/Time: Tue, 04 Mar 2025 15:18:23 +0000
[User Discussion] - Hotkey for
View Count: 465
[2021-12-16 01:43:03]
j4ytr4der_ - Posts: 946
I'm doing some experimenting with the Order Allocation feature. But to disable it, I have to go clicking through menus/dialogs to do it. Is there a hotkey for it? I don't think there is but thought I should ask rather than assume. If not, could a hotkey be added for this option to enable/disable it? Also if it's used in conjunction with a spreadsheet system, could it be possible to enable/disable it from the sheet?
