Date/Time: Tue, 26 Nov 2024 02:15:47 +0000
Totals on Pulling and Stacking Column
View Count: 936
[2021-12-15 18:42:36]
User135370 - Posts: 162
Hi John/Sierra
Is there a way to remove the totals of the pulling and stacking column, I disabled Depth totals but it doesn't seem to disable Pulling and Stacking totals, in the attached image they are the outer columns showing only 1 level
imagePulling and Stacking totals.JPG / V - Attached On 2021-12-15 18:42:20 UTC - Size: 86.57 KB - 300 views
[2021-12-16 15:49:41]
John - SC Support - Posts: 36286
There is not a way to turn those off. We have set this as a Feature Request.
[2021-12-16 16:17:53]
Ok John on the same topic is there a way to see what has been pulled stacked at a level similar to the volume profile but based on pulling stacking data? Is that even doable?
[2021-12-16 18:04:42]
You can turn on the Volume Bars for the Pulling/Stacking, but they only reflect the positive values, not the negative. That is yet another feature that we need to get to.
Refer to the following for how to enable the Volume Bars for a DOM column:
Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns)
[2024-01-14 17:20:48]
binaryduke - Posts: 369
@SCE
It would be very useful if we could color the totals according to positive/negative in the same way as the individual pulling/stacking (at each price) values. Right now there's only a single DOM/ChartDOM Totals color in Graphics Settings.
