Date/Time: Tue, 04 Mar 2025 15:02:30 +0000
Issue with Sierra Charts limiting my profit
View Count: 624
[2021-12-15 15:57:06] |
User818352 - Posts: 4 |
Hello, I see a limit of 236.25 (ES) on my sierra charts and it pushes me out at that point when im in a trade. Is this a bug? |
[2021-12-15 16:33:40] |
I see a limit of 236.25 (ES) on my sierra charts Where in Sierra Chart do you see this? We do not know what you are referring to.
[2021-12-15 16:55:00] |
okay let me rephrase the query! My position automatically flattens when it hits a profit or loss of 236.25 points. As soon as i clear my trade activity, i am able to trade again! but if I don't clear my trade activity, It does not allow me to enter any new trades (so flattens me out at 236.23 points and does not let me enter new trades post that) |
[2021-12-15 17:34:21] |
John - SC Support - Posts: 38341 |
On your Trade Activity Log look at the source of the flattening to determine where it is coming from (Order Action Source field). Refer to the following: Trade Activity Log: Trade Activity Fields Although it does not sound like it is the Global Profit/Loss Management, this is something to check on. Select Trade >> Global Profit/Loss Management to see if this is enabled to take you out at a particular profit or loss level. Refer to the following for this feature: Global Profit/Loss Management For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-17 13:01:01] |
Refer to: Trade Activity Log Analysis: Determining the Origin of a New/Modified Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
