Date/Time: Tue, 04 Mar 2025 16:33:52 +0000
Copy lines from a study into a other chart
View Count: 1158
[2021-12-14 21:31:21] |
User152844 - Posts: 6 |
Hello, I use weekly VWAP on one chart and Daily VVWAP on a other chart. I would like to see the 2, 1, VWAP, -1, -2, deviation lines from the weekly VVWAP displayed as straight lines on the chart with the daily VWAP. How do I do this? Illustration picture attached. Thanks. Steffen |
Attachment Deleted. ![]() |
[2021-12-14 23:10:58] |
John - SC Support - Posts: 38354 |
If we are understanding this correctly, you just want to see the most recent value of the weekly VWAP on the daily chart projected forward. In this case, you would use the Study/Price Overlay study on the Daily chart and reference the Weekly VWAP study on the other chart. Then you would set the following on the Study/Price Overlay: - Use Styles and Widths from Source Study: No (select Apply after changing this) - For the subgraphs you want to display change the Draw Style to: Line at Last Bar to Edge Refer to the following for the Study/Price Overlay: Study/Price Overlay Study And refer to the following for the Draw Style of "Line at Last Bar to Edge": Chart Studies: Line at Last Bar to Edge (ACSIL: DRAWSTYLE_LINE_AT_LAST_BAR_TO_EDGE) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-22 10:35:43] |
Hi, Thank you for your advice it worked! However I just opened the exact same Chartbook on a different computer and the overlayed Weekly VWAP lines where placed differently. Please see the attached files. How do I correct this and how do I in general make sure that the overlayed lines are displayed correctly before trading? Thanks in advance. Steffen |
[2021-12-23 00:52:40] |
We do not understand exactly what the issue is. Go through all of the items here to determine what the issue is: Chart Studies: Resolving Study Differences (Resolving Study Differences) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
