Date/Time: Wed, 27 Nov 2024 20:36:35 +0000
Triangle Drawing Tool
View Count: 1718
[2013-04-24 16:21:22]
User6191 - Posts: 6
Would you please consider adding a TRIANGLE drawing tool to your list of tools. When looking for patterns, the triangle tool is quite helpful and having to drawing with the line tool is tedious. Thank you.
[2013-04-24 18:33:26]
Look at the Marker tool.
[2013-04-25 03:44:02]
User201106 - Posts: 62
I suggest that you try the Zig-Zag drawing tool for a triangle. It is much easier to draw a pattern with it versus the single line tool. Just draw a side (line) and click to begin the next side (line) and so on.
[2013-04-25 14:41:59]
Bruce Heubach - Posts: 16
SC support, the marker tool is a marker, it is not a tool. Thanks Canyon2, that's a great use of the zig-zag tool.
[2014-05-13 15:52:02]
bwalks123 - Posts: 122
Yes can the addition of Triangle Drawing tool please be added. The ZigZig tool works well to draw patterns but I believe most people that are drawing triangles like myself are needing to paint/fill the triangle in with a separate color to make it stand out better. Same concept as the Ellipse tool but a Triangle. Thanks
[2014-10-13 12:32:06]
madmedmat - Posts: 13
+1
I could use a triangle that works similar to a rectangle/ellipse, but with the option to extend it (like extending rectangle) and of course, fill it.
Date Time Of Last Edit: 2014-10-13 12:33:46
