Date/Time: Fri, 25 Sep 2026 08:47:01 +0000
Moving stop loss with hotkeys instead of moving it by the mouse
View Count: 1379
[2021-12-14 12:47:23]
User525866 - Posts: 1
Hello, I wanted to know if we can move our stop loss with hot keys ?
For exemple everytime I press "+" on my keyboard, I want my stop to move +1 tick,
and eveytime I press"-" on my keyboard, I want my stop to move -1tick,
It would be so helpfull for agressive scalping. ( I dont have time to move the mouse)
Thank you.
[2021-12-14 16:08:50]
John - SC Support - Posts: 48003
There are keyboard shortcuts that can be set for the following items which are located under the Trading Keyboard Shortcuts:
- Stop Order Tick Up
- Stop Order Tick Down
There are also other items in there that you may be interested in.
Refer to the following for how to create Keyboard shortcuts:
Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu)
