Date/Time: Tue, 04 Mar 2025 13:31:46 +0000
Real time data
View Count: 712
[2021-12-13 21:06:47] |
ronaknathwani - Posts: 13 |
Dear support Is there any future development path to address the issue when downloading the "ticker" all other platform i have used like TOS, tradingview etc the chart are loaded instantly. Also the ticker data it holds takes too much space on the PC and if i was to delete its were are back to same slow process of downloading data. especially if I'm looking for big caps stocks. mr nathwani |
[2021-12-14 19:33:34] |
Sierra_Chart Engineering - Posts: 18641 |
There is nothing for us to do. You already have the ability to fully control this. Set this to 1 Minute: Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings) After that re-download the data for each symbol: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-14 19:33:53
