Date/Time: Tue, 04 Mar 2025 14:55:44 +0000
Feature Request for DOM Columns (Ask minus Bid Volume)
View Count: 1056
[2021-12-13 19:24:31]
AC7303484 - Posts: 28
I would like to see if it would be possible for Sierra to add Ask minus Bid Volume at price as a column option in the DOM.
I know this can be done via a volume profile (which is how I utilize it now) but it would be incredibly helpful to be able to get this data as a column the DOM itself. I've attached a picture for reference but should be pretty straightforward.
Thanks!
imagesierraDOMrequest.jpg / V - Attached On 2021-12-13 19:23:36 UTC - Size: 227.43 KB - 240 views
[2021-12-14 04:12:25]
Kevin941 - Posts: 22
I think this would be a great addition to the Sierra DOM!
Thanks!
[2021-12-14 04:14:16]
Bear Goes Long - Posts: 2
Agreed. A DOM column text value for this would be very helpful!
[2021-12-15 19:22:12]
Rathinp - Posts: 3
Yes... This will defs add value!
[2021-12-17 03:18:42]
Any updates would be appreciated
[2021-12-17 15:08:34]
John - SC Support - Posts: 38341
We have this as a Feature Request, but we do not have any idea of when, or if, we will get to this. This is true for all our development items. We can not give specific information for any particular update until it is actually done.
