Date/Time: Tue, 04 Mar 2025 12:12:49 +0000
Activation
View Count: 619
[2021-12-13 17:11:48] |
rdh - Posts: 3 |
Hi there, I'm looking for live data for FX (optional), NQ and Crypto. I bought 6 months of package 3 - is this correct? I am not seeing any data though, and getting this error (attached screenshot). Kind regards, Ross |
[2021-12-13 19:21:36] |
John - SC Support - Posts: 38341 |
There is no attachment, so we do not know what error you are seeing. But you should be getting data for FOREX and Crypto, as those data are available at no extra cost with any Sierra Chart package. Let us know if you are not getting these data. In order to get the data for NQ, you would need to use the Denali Exchange Data Feed and activate the appropriate exchanges. Just keep in mind that in order to get the CME Group data at the non-professional rate, you need to have a live, funded, futures trading account that you can connect to at least once a month. Refer to the following for more information: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you do not have a trading account, then refer to the following for a way to setup an account for a minimal outlay of funds: Easy Solution to CME Funded Trading Account Requirement Once you have the above worked out, then you can activate the Denali Exchange Data Feed by following these instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
