Date/Time: Tue, 04 Mar 2025 12:28:53 +0000
Tradeovate/Dorman LLC Broker Linking
View Count: 1023
[2021-12-13 15:40:37]
Trading Jules - Posts: 3
Dear Sierra
I have the Sierra Charting Platform as well as Tradeovate. My Tradeovate is currently linked to my Trading View Charting Platform to place orders on both Trading View and Tradeovate. I receive Live data feeds from Tradeovate in Trading View. My queries are as follows:
1) Can I link Tradeovate, more specifically Dorman LLC, as my Broker with Sierra?
2) If so, what would be the related costs? From next month, I would only like to receive live data feeds in Sierra for ES and NQ, Package 11
3) Would I need to pay for data feeds from both Sierra and Tradeovate, when linking Tradeovate/Dorman to Sierra?
4) Using Tradeovate/Dorman LLC as my Broker, could I switch my order routing directly to Sierra Order Routing for placing those Sierra trades directly from and through Sierra?
Thank you kindly. Look forward to your feedback.
Kind Regards...Juliet
[2021-12-13 18:57:23]
John - SC Support - Posts: 38341
1) As long as your setup with Tradeovate is using CQG or Rithmic, then you would be connecting your Sierra Chart to the CQG or Rithmic account.
2) Package 11 is $46.00 per month. The data feed costs will vary depending on what you need. Refer to the options at the following link:
Denali Exchange Data Feed: Supported Exchanges (Exchange Fees)
3) If you are wanting to continue to get data to both systems, then yes, you would need to pay for the data from both systems.
4) Although you could possibly use the older Sierra Chart Order Routing Service, we are phasing that out in favor of our Teton Order Routing Service. Therefore, you would probably not be able to switch right now, as Dorman is not supporting the new order routing service yet.
