Date/Time: Tue, 04 Mar 2025 12:25:32 +0000
Study Price Overlay query
View Count: 490
[2021-12-13 14:50:44] |
User135370 - Posts: 162 |
HI My main chart is a Number bar 5 Min time Frame I want to overlay the Number Calculated Value from the 1M 30 M and 60 Min on the Main chart in the indicator pane When I do this it changes the other charts to the same time frame as the main chart (5 Min) I used this with other indicators and it worked if I recall, why not in this case Is there a way to make it work |
[2021-12-13 18:31:20] |
John - SC Support - Posts: 38341 |
Numbers Bars Calculated Values are special and can not be easily overlaid to another chart. What is happening to you is one of the consequences, the chart Time Frames must be exactly the same. Refer to the following: Numbers Bars: Overlaying a Numbers Bars Calculated Values Study from Another Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
