Date/Time: Tue, 04 Mar 2025 12:23:51 +0000
Study Subgraphs Reference for another Chart?
View Count: 1140
[2021-12-13 12:16:47] |
ycomp - Posts: 321 |
Is there a Study that can reference a Subgraph in another chart and expose that as a Subgraph? Something like "Study Subgraph Reference" or "Study Subgraphs Reference" but that refers to another chart's Study's subgraph(s)? Date Time Of Last Edit: 2021-12-13 12:17:22
[2021-12-13 18:24:21] |
John - SC Support - Posts: 38341 |
There is not one that explicitly does this. You could use the Spreadsheet Study to accomplish this, however, by using the same Spreadsheet on two different charts and then you can reference between the sheets to get the information from one chart's study to another chart. Also, be aware that there are a few studies that can reference data from another chart, so you might have what you are wanting in the end, already available. You will find these listed in the Technical Studies Reference with a name that ends in "From Chart". For example, there is the Text Display for Study from Chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
