Date/Time: Tue, 04 Mar 2025 12:04:49 +0000
Prices on my Chart are not correct but my DOM has the correct prices
View Count: 497
[2021-12-12 23:16:34]
Francis Quansah - Posts: 1
Trust you are doing well. Please on my chart, the price on the Y axis is not correct but on the DOM it shows the correct price. Is there anything i can do to get the price to sync with each other?
I have attached a screenshot for your perusal.
Regards
imageDOM Price.PNG / V - Attached On 2021-12-12 23:14:29 UTC - Size: 34.69 KB - 131 views
imagePrice Chart.PNG / V - Attached On 2021-12-12 23:15:22 UTC - Size: 11.44 KB - 139 views
[2021-12-13 17:49:45]
John - SC Support - Posts: 38341
Make sure the chart is scrolled all the way to right. You may have locked the fill space, so although it looks like you do not have any additional bars, they are still there, just hidden by the fill space. You will know if you are scrolled all the way to the right when the indicator in the bottom left corner is highlighted in Green (by default). Refer to the following:
Chart Settings: Lock Fill Space (Chart >> Chart Settings >> Display >> Chart Display Items menu)
