Date/Time: Tue, 22 Sep 2026 04:14:33 +0000
Spreadsheet programming question #CREF using Locking the State of a One Time Condition
View Count: 1222
[2021-12-12 22:17:06]
User183724 - Posts: 194
Does anyone have a working example of a "Locking the State of a One Time Condition" ? I've tried a thousand combinations and get #CREF every time. I have a 5 minute chart with a BAR NUMBER STUDY. I'm attempting to allow a cell to be updated only once per bar#.
If this isnt possible, i'd be ok with some formula using a version of bar time or FRACTIME ...?? where the new bar time allows the cell to update but havent had any luck getting that to work either. basically, i want the cell to only update once per bar.
Spreadsheet Studies Special Tasks
[2021-12-12 23:11:10]
Sawtooth - Posts: 4354
Here's another example:
https://www.sawtoothtrade.com/example-9.html
[2021-12-13 00:04:10]
thanks.. i looked at that...got #cref with it too
[2021-12-13 00:51:33]
The example does not create a #CREF.
Try this exercise:
1. Put this formula in cell H3:
=AND(OR(H3=TRUE,H4>1),H5)
2. Put a 1 in both H4 and H5. H3 will be 0, and ready to be locked.
3. Put a 2 in H4. H3 will go to 1, and be locked.
4. Put a 1 in H4. H3 remains a 1 because it is locked.
5. Put a 0 in H5. H3 will go to 0, and be unlocked, but not ready to be locked again.
6. Put a 1 in H5. H3 remains a 0, but is ready to be locked again.
I admit it can be tricky to get this to work automatically, especially the unlocking and rearming portion.
Steps 3 & 4 can easily be done automatically because this is the event that you want to lock TRUE.
Steps 5 & 6 can be tricky to get to work automatically because you need an event that changes state, followed by a change of state in the opposite direction.
IOW, step 5 can be 0, and step 6 can be 1, or vice versa if H5=0.
[2021-12-13 01:29:42]
i've been trying all that for several days... I've pretty much give up on it for now...thanx anyways.
[2021-12-15 05:46:32]
j4ytr4der_ - Posts: 947
In case it's helpful to anyone... here's another (commented) approach...
=IF(REM="How to set & lock a state","",
  IF(
    AND(
      IF(REM="If state #1 is true...","",""),
      J5 <> 0,
    AND(
      IF(REM="then set this cell (O3) to true","",""),
      O3 = 1,
    AND(
      IF(REM="Otherwise keep the value at this cell's value...","",""),
      O3
My platform's shut down at the moment so I didn't test this, but it's just a slightly modified copy & paste out of a project I'm working on right now so... reasonably certain it's lacking in huge errors. Reasonably. =D Obviously it can be cleaned up & condensed without all the comments, just including them to help folks understand the logic.
