Date/Time: Tue, 04 Mar 2025 12:06:14 +0000
MCL Not Showing
View Count: 450
[2021-12-11 09:47:25] |
User240019 - Posts: 112 |
Hi, I have access to NYMEX, I have access to the CL contract, but I'm not seeing the CL micro contract. My broker says they've enabled it and I should check with you since they don't have anything else they can enable. Can you help me figure this out ? I have denali, so I'm a little confused. It seems like it should just be listed in the NYMEX list of contracts. Please let me know |
[2021-12-12 14:04:35] |
You are not using the Denali Exchange Data Feed since you have not activated the NYMEX exchange. You can do this from here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed We cannot help with data direct from Rithmic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
