Date/Time: Tue, 04 Mar 2025 12:25:56 +0000
Disable an alerte
View Count: 536
[2021-12-10 19:06:17] |
pw4180100 - Posts: 5 |
how can i disable the alerte Symbol needs rollover. Click to rollover Thenk you |
[2021-12-10 21:18:09] |
John - SC Support - Posts: 38341 |
There is not a way to remove the message, just to move when it will show up. Refer to the following settings: General Settings Window: Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume (Global Settings >> General Settings >> Charts >> Symbol) General Settings Window: Additional Days to Add to Rollover Date for Chart and Quote Board Rollovers (Global Settings >> General Settings >> Charts >> Charts) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
