Date/Time: Tue, 04 Mar 2025 12:01:07 +0000
Connection to IB
View Count: 862
[2021-12-10 19:04:59]
Torsten Grüß - Posts: 45
Can you help me
I have problems connecting to TWS
- The order bar disappears after execution
- I can not trade many symbols because no order is transmitted to TWS see video http://somup.com/crl6DM05vN
What can I do, where is the error, have you changed something?
Back when the Fester Data / Trade Service Settings was still the old version, everything was OK.
For info I use SC data and for execution only the TWS
[2021-12-10 21:04:41]
I have found a problem, it is no longer enough to select the symbol PYPL I must enter in SC exactly PYPL-STK-NYSE-UDS
but this was not the case before or a year ago when it was sufficient to enter only PYPL.
Can I set something in SC to keep my old notation?
[2021-12-10 21:06:09]
John - SC Support - Posts: 38341
There is nothing you can do in Sierra Chart for this. It is just due to a change that we had to make for Interactive Brokers from some time ago. The requirement to have all the extra stuff for the symbol is what they are requiring.
[2021-12-10 21:13:10]
is there a possibility that the symbol is automatically dipped for the placeholder
BA-STK-NYSE-USD
#-STK-NYSE-USD
[2021-12-10 22:03:04]
GravisHTG - Posts: 306
I always use IB and i always just input /nflx or /ba on the chart and it give me the right symbol.
Only for options and Futures that I have to go in the F5 menu and input it myself.
I use Sierra chart data feed to get good live data and The latest software.
If this can help
[2021-12-11 08:37:43]
so I did it earlier (a year ago) but now I have problems with it.
With the share PYPL I get no execution or transfer to the TWS.
And with other stocks I get an execution but the order status bar disappears after 5 seconds.
@GrvisHTG can you please check this for PYPL with you if it works with you?
[2021-12-11 21:58:39]
They Symbol problem , I dont have any ATM , I know sometimes I need to delete my subinstance and reload it to make it work.
( i always use subinstance for charting ) my main have no charts.
but the order status bar disappearing after 5 sec, that happen to me and It wont go ,
The status bar only stay on my options graph.
Dev team , please look at this issus. Its a brand new issues that happen like 1 month ago. !
I port about it once , but I dont think you understood the issue.
Its when we trade , you know that line that indicate at what price you brought and if you are green or red on the trade in the graph.
Date Time Of Last Edit: 2021-12-11 21:59:37
[2021-12-12 14:47:15]
This does not make any sense and we never recommend doing this:
It is not a solution to any problem.
Regarding Interactive Brokers position reporting, refer to:
Interactive Brokers Trading Service: Trade Position Line or Quantity Disappearing or Displaying Zero
Make sure you are using the correct symbol:
Interactive Brokers Symbols: Stocks With Specified Exchange and Primary Exchange Format
[2021-12-12 22:40:21]
Ok , thanks for the answer Dev.
Ill check with IB what we can do for that LINE , guess , it was a change on IB side that happen around 1 month ago.
Just curious about why my option chart line stay , but my symbol line does not.
And as for the Deleting of my subinstance, Yes I understand that It should not be require , and most of the time , it does not fix the problem ,
But on some occasion ( very rarelly , to make it clear ) , I had weird stuff happening and It fix it :) So I guess , Can be helpfull sometimes :)
And it does not cost too much to just delete the sub and reopen the main instance !!
have a great day, And I cant wait to get the TotalView of the nasdaq !
Date Time Of Last Edit: 2021-12-12 22:41:16
[2021-12-13 15:18:04]
NASDAQ TotalView is coming we expect in December.
