Date/Time: Tue, 04 Mar 2025 14:49:43 +0000
Market data
View Count: 601
[2021-12-10 13:46:10] |
User304634 - Posts: 4 |
Hi Sierra chart team, How can I connect directly to the Rithmic direct connection data feed in a later version of sierra? Is there a way to replace specific files to solve this little problem without going through the Rim file Bridge. |
[2021-12-10 17:28:22] |
John - SC Support - Posts: 38341 |
There are no additional files needed any longer (hence the term "direct" in the title of the new connection). Just follow the instructions at the following link to connect your Sierra Chart to Rithmic: Rithmic Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-14 15:33:33] |
yes but on older version of Sierra chart i mean, i have an older version and i havent the direct connection, so how i do to connect to the direct data rithmic?
[2021-12-14 16:38:17] |
We recommend you move to a current release and just use the new direct connection to Rithmic.
[2021-12-14 19:56:53] |
Your Sierra Chart account was expired but we reactivated it temporarily. So you are able to test and have time getting connected to the Rithmic connection. Instructions: Rithmic Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-15 16:04:14] |
But i have a personalised study that doesn't run on the recent version of Sierra, so is there a way to replace some files used the old version with the new direct connection from rithmic?
[2021-12-15 16:49:07] |
No, this is not possible. If you need to use an old version you can try and continue to use the Bridge program, but we do not know if Rithmic is still supporting this or not. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-20 01:22:20] |
We can help you get this working: But i have a personalised study that doesn't run on the recent version of Sierra, Do you have the source code for this study? You should have no trouble running it on the current version of Sierra Chart.
