Date/Time: Wed, 23 Sep 2026 04:10:56 +0000
tpo chart not working
View Count: 995
| [2021-12-10 09:23:52] |
| User735660 - Posts: 3 |
Hi, I am having problems with TPO CHarts. Anytime I am trying to use it the laptop get stuck. My laptop has 16MB ram, and is I7 last ge11 wiht intel graphics. The ram works ok, at time to run the TPO is 50% useage. Can you help me to get a better performace? Should I upgrade the RAM? Regards |
| [2021-12-10 09:55:59] |
What is the symbol of the chart?
| [2021-12-10 10:10:20] |
ETH, BTC these two crypto from binance. ETH-USDT and BTC-USDT
| [2021-12-10 16:52:56] |
| John - SC Support - Posts: 47980 |
There is just a large amount of data in those symbols. You need to adjust the TPO Input for Letter/Block Price Increment in Ticks. You will need to set it to something rather large like 500. You will have to play with it to determine the best tradeoff of data vs performance. Refer to the following for this Input: Time Price Opportunity (TPO) Profile Charts: Letter/Block Price Increment in Ticks For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
