Date/Time: Mon, 10 Mar 2025 23:11:45 +0000
I want to use Sierra Chart with NinjaTrader Clearing
View Count: 1748
[2021-12-09 22:52:55]
Analytic - Posts: 2
Hi,I want to use Sierra Chart with Ninjatrader Clearing. Is this possible? If yes how would it be done? Thanks.
-Sholom
[2021-12-09 23:00:03]
John - SC Support - Posts: 38547
Is your Ninja Trader account setup with CQG or Rithmic for your Order Routing?
[2021-12-09 23:39:10]
Analytic - Posts: 2
CQG
[2021-12-09 23:51:31]
Then you would follow these instructions to connect your Sierra Chart to CQG:
CQG Trading Platform Service: Setup Instructions
[2022-04-19 00:25:17]
VerySherri - Posts: 3
Does this method work? The link @John-SC Support provided does not list Ninjatrader. For personal reasons I am unable to open a brokerage account elsewhere for the time being. I have an account with NT, using CQG Continuum.
[2022-04-19 14:05:58]
It should work, as our understanding is that it is a standard CQG connection. Just be aware that historical data from CQG is limited. Refer to the second bullet point here:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2351
