Date/Time: Tue, 04 Mar 2025 12:25:19 +0000
Footprint bars get frozen not loading data
View Count: 521
[2021-12-09 16:57:53] |
joplacas - Posts: 9 |
Hi, Everyday after sometime using without any issue SC, my footprint & TPO charts graphs with the ES emini, stop loading data and gets paralysed, although my DOM attached to it keeps moving real time. This also happens with NQ and other graphs. I have Denali pack 12. I have tried to Deleting / Downloading fresh data many times but nothing happens. Also following your first feedback some days back, I updated latest SC version (although I m a new customer) and also make sure the Session Times include the entire 24 hour time range. Do you need my chart book? it has no issues with other people using it. In fact, its not mine, is from The Pit. Best. Juan |
[2021-12-09 18:05:26] |
John - SC Support - Posts: 38341 |
When you see this occur, please take a screenshot of what you are seeing. You can get a screenshot by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
