Date/Time: Tue, 04 Mar 2025 12:28:37 +0000
data plan help
View Count: 474
[2021-12-09 16:24:34] |
jacob j brubaker - Posts: 5 |
hello, ive been having a hard time getting my account set up properly. which monthly plans and then service packages do i need to trade live stocks equities using Market Profile? thank you so much |
[2021-12-09 17:48:00] |
John - SC Support - Posts: 38341 |
The first thing we want you to be aware of is that we only have connectivity with Interactive Brokers for trading stocks at this time. We are working on a new data feed for U.S. Stocks, and we hope to get some additional brokers after we get that done, but we do not know for sure. In order to get the data for the U.S. Stocks, you would need to use the Sierra Chart Exchange Data Feed and enable the U.S. Equities exchange. Refer to the information at the following link for the Sierra Chart Exchange Data Feed, which also includes Setup Instructions: Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
