Date/Time: Sun, 09 Mar 2025 12:49:02 +0000
View Count: 1139
[2021-12-09 15:30:03] |
Пользователь488020 - Posts: 100 |
Hello. In the link Sierra Chart Teton Futures Order Routing in paragraphs 2 and 3 of the Setup Instructions there is an AMP futures. I turned to the AMP but was denied routing with AMP. What should I do? |
[2021-12-09 17:16:49] |
John - SC Support - Posts: 38516 |
As noted after AMP, it states in parentheses "Intending to support. Not yet available." Therefore, this is not yet available with AMP. If you want to stay with AMP, then you would need to be setup to use CQG or Rithmic at this time and then when the Teton Direct Order Routing is available with AMP, you can switch over. Otherwise, you would need to switch to one of the other brokers that supports this service, such as Stage 5 or Advantage. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-09 19:02:11] |
I was told that No ETA
[2022-03-06 05:35:55] |
User630795 - Posts: 92 |
AMP is saying that they want to see over 1,000 accounts on Teton. How many do you currently have using Teton? If it is over 1,000 users, you should let AMP know.
