Date/Time: Tue, 04 Mar 2025 12:21:11 +0000
Left Click
View Count: 574
[2021-12-09 11:46:08]
User701018 - Posts: 12
When I'm using the mouse left click a text window box is opened, I can't find the place to turn it off and it's very difficult to work like this.(attached picture)
second question:
Can I connect Sierra to Ameritrade account?
Thanks,
Galit
imageIMG_5061.jpg / V - Attached On 2021-12-09 11:44:01 UTC - Size: 870.17 KB - 150 views
[2021-12-09 16:40:55]
John - SC Support - Posts: 38341
You have one of the Text drawing tools enabled. Change your drawing tool to a different one by selecting the tool you want under the Tools menu. Pointer, in particular is the drawing tool that has no interaction with the chart.
Refer to the following:
Chart Drawing Tools: Pointer
