Date/Time: Tue, 04 Mar 2025 19:09:32 +0000
[User Discussion] - Timer based copy paste formula in Spread sheet
View Count: 576
[2021-12-09 11:43:40]
VolTrader73 - Posts: 136
Id like a formula in spread sheeet that can copy (capture) the value only of a cell to another.
For example -
I have a formula in Cell A that dose some manipulation on the price.
It shows a continually updating value.
Id like to have a timer that will copy that value (only the static value captured) every 60 seconds to another cell.
I had this working in Microsoft excel but have no clue as to how and do this with SC..
Thank you
[2021-12-09 13:14:06]
Sawtooth - Posts: 4179
It's not possible to capture a cell's dynamic value intrabar.
The solution would involve using a 1 min chart so that every new bar had the static value.
You could then overlay that to another chart using the Study/Price Overlay study.
[2021-12-31 15:41:55]
For something like this you have to use ACSIL to interact with a Spreadsheet Sheet:
ACSIL Programming Concepts: Direct Programmatic Interaction with Spreadsheet Sheets
Therefore, it is definitely possible to do what you want.
Date Time Of Last Edit: 2021-12-31 15:42:31
