Date/Time: Tue, 04 Mar 2025 10:12:37 +0000
Numbers Bars Calculated Values - Wrong Min / Max Delta Values
View Count: 752
[2021-12-08 20:34:39] |
User100341 - Posts: 1 |
Hi SC Team, My 10 range bar (true in ticks) chart has wrong min/max delta values very frequently. I attached the below example screen. Could you please correct this miscalculation? Thank you. Deniz. https://www.sierrachart.com/image.php?Image=1638995280314.png |
[2021-12-09 00:31:13] |
Sierra_Chart Engineering - Posts: 18641 |
There could not be a miscalculation here. That is impossible. In that screenshot the text you have in yellow, the conclusion is wrong. It is not likely the calculation would ever be zero. It absolutely can start off positive.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-09 00:32:04
