Date/Time: Tue, 04 Mar 2025 10:36:12 +0000
Anyone else using a Surface Pro to run Sierra Charts on?
View Count: 1094
[2021-12-08 20:07:47] |
User570216 - Posts: 6 |
I would really like to try using Sierra Charts on a Microsoft Surface Pro. Requirements recommendations are for 32GB RAM for any device you use, but I notices my PC only has 4GB on it and runs Sierra just fine, so I would thing the Surface Pro with 16GB RAM would work just fine. Anyone else already tried and can share their experience?
[2021-12-08 20:14:26] |
Yes Sierra Chart does run a Microsoft Surface Pro. We do use one, it runs just fine and very well. 16 GB RAM is more than sufficient. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-08 20:15:06
[2021-12-08 22:48:07] |
JonoVo2 - Posts: 4 |
I use a Surface Pro 4 when travelling (I travel a lot) and as SCE said it works perfectly. If I don’t get time to update my desktop when I get home I just plug in a 23” monitor - using a mini dp to hdmi dongle - and it still works perfectly. |
