Date/Time: Tue, 04 Mar 2025 11:59:15 +0000
data delay 10mins
View Count: 509
[2021-12-08 18:21:50] |
User912652 - Posts: 3 |
Hi there I recently signed up the Sierra and wondering how may I fix my data(10mins delay) to current? Please advise the step by step instruction or guide video Regard, Amulek |
[2021-12-08 18:40:14] |
John - SC Support - Posts: 38341 |
You have signed up for the Non-Professional CME exchanges, which means that you need to connect to your live, funded futures trading account at the beginning of each month to qualify for the lower-priced exchange fees. You have not connected to your trading account yet this month. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-09 17:17:24] |
I did the instruction below Select Global Settings >> Data/Trade Service Settings >> Common Settings. Enable Allow Support for Sierra Chart Data Feeds. Press OK. Select File >> Disconnect. Select File >> Connect to Data Feed. still no real time data, what part am I missing??? |
[2021-12-09 18:06:40] |
You need to do the part in Step #3 where you connect to your live, funded, futures trading account. What broker or trading service are you using?
[2021-12-13 04:36:18] |
I use TOS
[2021-12-13 17:56:57] |
Unfortunately we do not support connectivity with TD Ameritrade. Therefore, you can not use that to validate your non-professional status for the CME Group. In this situation, we recommend the solution outlined at the following link: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
