Date/Time: Tue, 04 Mar 2025 10:06:18 +0000
Headers on each volume profile
View Count: 529
[2021-12-08 14:53:19] |
User841161 - Posts: 248 |
Can title headers be put on each session automatically with possibly a study. I know it can be done manually with chart tools, but looking to see if it would write titles on each day above each volume profile. Here is picture of something similar to what i am looking for. Thanks |
Attachment Deleted. |
[2021-12-08 16:06:18] |
John - SC Support - Posts: 38341 |
The only items that can be automatically added would be those that are part of the study. Refer to the documentation at the following link for the information on what we are referencing: Volume By Price Study: Show Chart Values On Profile You could set up the values to display as you want and then save them as the Default Study Settings. Refer to the information at the following link: Chart Studies: Using Custom Default Study Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
