Date/Time: Tue, 04 Mar 2025 10:24:18 +0000
flux direct
View Count: 659
[2021-12-08 01:04:40]
User338651 - Posts: 14
re bonjour , je vous ai poster une demande d'aide pour un flux en temps réel sans compte de trading, j'ai commencer a suivre les instructions en partie , j'ai déjà payer,
je pense avoir fait correctement les processus ,réponse a votre question , ce serai pour travailler avec CME POUR LE SP500
merci d'avance pour votre intervention
salutations
[2021-12-08 15:18:38]
John - SC Support - Posts: 38341
From Google Translate:
Hello again, I posted you a request for help for a real-time feed without a trading account, I started to follow the instructions in part, I have already paid,
I think I have done the processes correctly, answer to your question, it will be to work with CME FOR THE SP500
thank you in advance for your intervention
greetings
In the Exchange Agreement you specify that you are a Non-Professional. The CME Group will not allow you to get the data at the non-professional rates without having a live, funded, trading account. For more information, refer to the documentation at the following link:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
At this time, you have not properly filled out the Exchange Agreements, so you are not able to continue activating the Denali Exchange Data Feed.
In order to continue, you must first determine whether you will pay the Professional exchange fees or if you will open a trading account in order to qualify for the non-professional rates.
If you are interested in opening a trading account for this purpose, then we recommend the service outlined at the following link:
Easy Solution to CME Funded Trading Account Requirement
