Date/Time: Tue, 04 Mar 2025 09:14:59 +0000
Crypto data feed
View Count: 790
[2021-12-07 22:35:41]
william bolger - Posts: 29
I am trying to access crypto data feed. Is there a link on where to read up?
When I go to symbols and "get binance symbols" it doesnt populate anywhere.
Any suggestions?
[2021-12-07 23:11:41]
John - SC Support - Posts: 38341
The documentation for our Crypto feeds can be found here:
Cryptocurrency / Bitcoin Data and Trading Services
To get the Binance Symbols you need to open the section in the Find Symbol window and select the item that states "(Get Binance Symbols)", and then you need to select the button that states Get Symbols on the bottom half of the screen. Refer to the instructions here:
File Menu: Getting Symbols
